Author Topic: What is the "collar" in the trans?  (Read 4623 times)
donut
« on: July 13, 2012, 03:33:40 AM »
Yet another newb question.
I took the '01 ZX into the scoot shop...
Scoot shop owner took it for a spin to give me his opinion...as I have never ridden a "good" or any ZX... just Peoples and the ZX seemed "clunky" to say the least.
He schooled me the apples and oranges between the ZX and People... stated the ZX (stock of course) is a slower start off the line...
but he thought the transmission might be off...and
Had a leak coming from the carb ...
so I agreed to an hour labor to reconnect the carb nipple and check the trans...
he discovered the "collar' was the wrong part/size (meant for a People, etc but not the ZX) and he replaced it...
whew, so hopefully this makes sense as I have explained what I remember but now would someone school me please as to what the collar is and what it does?
thank you in advance for your patience...
Re: What is the "collar" in the trans?
« Reply #1 on: July 13, 2012, 06:19:45 AM »
I believe he meant the drive boss. The ZX takes a shorter boss by 4mm. It's a 34mm boss
« Reply #2 on: August 15, 2012, 11:29:17 PM »
...i did not know that...
               8)
..that explains why my buds zx shows only about 4/5 of belt travel on the variator...
..i bet itsa 38mm, smooth gy6 boss....
« Last Edit: August 15, 2012, 11:32:03 PM by wordslinger »
« Reply #3 on: August 16, 2012, 03:05:50 AM »
Have him cut it to 34mm, and he will get an extra 5mph. Otherwise he has to get the OEM boss from Stadium, or a Nakaru from Racing Planet. I bought 4 nakaru's, and Know they are correct.
« Reply #4 on: August 16, 2012, 03:09:20 AM »
...lol...yeah, we already talked about it...
                           ;D
..imma hack off 4mm tomorrow!!!!
..thanx z!             :-*
« Reply #5 on: August 16, 2012, 03:15:46 AM »
Guess I'm getting Mad Cow or sober. Can't really tell.
« Reply #6 on: August 16, 2012, 03:18:23 AM »
..that mad cow stuff issa bitch...makes me change her plug...
Peters
  • In Glock I Trust
« Reply #7 on: August 21, 2012, 02:14:33 AM »
You guys know what the boss length is supposed to be on my people?
*2001 ZX-50 beater
« Reply #8 on: August 21, 2012, 02:46:07 AM »
38mm
Peters
  • In Glock I Trust
« Reply #9 on: August 21, 2012, 03:13:06 AM »
Cool  :)
I'll check the length next time I'm in there
It's the one that came with the Malossi multivar
*2001 ZX-50 beater
« Reply #10 on: August 21, 2012, 03:16:13 AM »
Naraku makes a shim washer kit if you are too short. It really is meant to get wide enough so the belt rests on the drive boss.
Peters
  • In Glock I Trust
« Reply #11 on: August 21, 2012, 03:19:39 AM »
Right
My concern is that it's too long. I understand that causes problems too.
I've found the restriction on the torque driver. I was wondering, if I ordered one from Stadium would it be restricted too?
*2001 ZX-50 beater
« Reply #12 on: August 21, 2012, 03:34:00 AM »
YES it would be restricted unless you specified an after market. The best test is still marking the var, and TD to see how far it all travels. Then figure why/where...
Peters
  • In Glock I Trust
« Reply #13 on: August 21, 2012, 03:37:35 AM »
Will do
*2001 ZX-50 beater
« Reply #14 on: August 21, 2012, 02:37:41 PM »
"I've found the restriction on the torque driver. I was wondering, if I ordered one from Stadium would it be restricted too?"
The Agility 50 has an un restricted TD you can use. Same for the ZX 50. Both have the same drive, and they will swap out for the people.
