Author Topic: Found larger windshield for PS250  (Read 1306 times)
lcstatema
« on: May 18, 2009, 07:59:23 PM »
Found a larger windshield for PS250. Only $60!
http://www.kymcoaccessories.com/windshields.htm
I've got one on order. I'll let y'all know how it works after I install it.
richbury
Re: Found larger windshield for PS250
« Reply #1 on: June 03, 2009, 01:52:34 PM »
thanks for the heads up,i have been looking for a taller windscreen, have you been able to install it yet?
richbury
« Reply #2 on: June 13, 2009, 10:11:54 PM »
I ordered the windscreen and installed it,not a very good fit for a s250. Seeing that it was a thinner more flimsy windscreen than the factory
installed, I was not willing to break off the tabs of my original mounting equipment.With the hope that i'll find a more suitable windscreen later.
Enter the drill and dremel tool.Traced the outline of the original screen drilled appropriate holes and cut the outline .Mounted  OK, with just
the original hardware.
