As some of you know from other thread,I was thinking of getting a clutch,and some of you recommended I change spings first.So since I got a spare clutch with the new/used pulley set I bought,I decided to try wordslinger's method using a small flat tip screwdriver.It worked great for taking them off but the shaft wasn't skinny enough to put them back so I used a spanner type screwdriver to push the spring hook over the hole it goes in....worked pretty slick too.So after a quick few shorts runs,I'm now launching in the powerband,somewhere between 8500 to 9000 rpm and staying there until it starts to top out then it keeps climbing until I hit top speed.So now the question is,how much would a new aftermarket clutch improve takeoff beyong this? I'm just debating whether it would be worth the coin on stock horsepower? Any ideas guys?
