Author Topic: Problem with fuel starvation  (Read 8141 times)
Re: Problem with fuel starvation
« Reply #30 on: July 24, 2012, 07:55:20 AM »
I had an intake valve go bad, and it was all the same symptoms. Just get an ebay head for 30-40- bucks, and be sure to ask the seller FIRST if it has steel valve seats. If not find another
The Rookie
« Reply #31 on: July 24, 2012, 01:28:16 PM »
OK local shop just got back to me, low compression.
As I'm off on Business next week and taking her to and from work costs about £8/day more than the Scoot I'm probably just going to suck it up and get them to fix it.
streido
« Reply #32 on: July 24, 2012, 02:53:15 PM »
Bummer but at least you know whats wrong now.
So what caused it to happen do you reckon? Did they say?
Chaos is my co-pilot.
The Rookie
« Reply #33 on: July 24, 2012, 03:27:56 PM »
No, guy who collected said he thought it turned over a bit easily (It's always been quite easy, first and only 50cc I've ever worked on so assumed it was 'normal'), they ran a quick comp test and its come back very low (didn't ask for a value), they'll probably have the head off later today or tomorrow.
streido
« Reply #34 on: July 24, 2012, 04:51:11 PM »
Well keep us posted how it works out. Hopefully they get it fixed up ok.
whiteknight
  • ..Knight Tweed..
« Reply #35 on: July 24, 2012, 06:38:43 PM »
i still reckon there will be a problem with it even after they try to sort it. i had the EXACT same problem with my scoot. everything checked out fine compression wise, but it was the diaphram in the carb that was letting it down, somthing had happened to the diaphram so the slide wouldnt work properly hence no fuel getting to the engine and it constantly cut out. when i fitted the new carb i had no more probs with it and it ran fine. if you were to get a new slide and diaphram i bet it would work a treat.
The Rookie
« Reply #36 on: July 24, 2012, 08:57:49 PM »
Well the Diaphragm was good when I checked it is all I can say!
streido
« Reply #37 on: July 24, 2012, 09:39:32 PM »
We'll find out soon enough, whens it due back? End of the week maybe?
The Rookie
« Reply #38 on: July 25, 2012, 05:20:36 AM »
No idea yet!
whiteknight
  • ..Knight Tweed..
« Reply #39 on: July 25, 2012, 08:54:17 AM »
mine looked in top shape when i had the carb in bits but the slide wouldnt work and the bike still wouldnt start. which would suggest that the diaphram wasnt working properly.
The Rookie
« Reply #40 on: July 25, 2012, 01:32:47 PM »
Rings piston and bore shot, rebuild cost horrendous so will have to look at DIY I think, how hard is it? Any ideas where to get a kit from UK?
http://www.ebay.co.uk/itm/KYMCO-AGILITY-50-4-STROKE-ALLOY-CYLINDER-AND-PISTON-KIT-/270659042035?pt=UK_Motorcycle_Parts&hash=item3f04893af3
« Last Edit: July 25, 2012, 01:37:11 PM by The Rookie »
« Reply #41 on: July 25, 2012, 01:43:08 PM »
..woww...did you see them?
..how many kilometers and what year of scoot??
..this will be the first time i can recall hearing of an un-modded piston failure on an agility...
The Rookie
« Reply #42 on: July 25, 2012, 02:02:35 PM »
8500 miles (about 13000km) did come with no air filter and had been messed with but seemed OK, apparently had run low on oil yet it had only done 130 miles since I topped it up so can only assume the rings were on their way out and it burnt it all!
Think I'll get it back and get that kit if people think it will fit OK....
« Reply #43 on: July 25, 2012, 02:36:59 PM »
..aahhh...that explains it...
The Rookie
« Reply #44 on: July 25, 2012, 02:43:49 PM »
Yes, seemed to run OK, not burning oil (visibly) and told it had only just fallen off...
So will that kit fit and will I need new mains and possible crank do you think?
