Did you miss your
activation email
Scooters - 50cc
Super 8
Naraku Traffic 4-Stroke 50cc
Pages:
3
Topic: Naraku Traffic 4-Stroke 50cc (Read 8500 times)
bahiano
Newbie
* 90cc big bore rocks! *
Re: Naraku Traffic 4-Stroke 50cc
Reply #30 on:
August 15, 2012, 11:51:51 AM »
@Zombie... here my new vid... still ticking, Valve adjusted, Intake 0,08 Ex 0,1..... what can it be that it is still ticking?
Last Edit: August 15, 2012, 12:12:58 PM by bahiano
You never know do ya!
Close enough to get the idea!
Reply #31 on:
August 16, 2012, 06:54:31 AM »
One of the con rod bearings. Turn the crank by hand back, and forth to see if you feel any play or the actual click. If that is not a valve it is the conrod. Have you ever had the cylinder head off? Or more specifically the rocker arms? Did the rockers move freely when you adjusted the valves?
I want to be SURE that is not a valve ticking before telling you if it is the Conrod you will have to rebuild/replace the engine. From the sound of it I wouldn't venture far from home either. Actually I wouldn't ride it. It will break.
Reply #32 on:
August 16, 2012, 06:56:33 AM »
I hear a single "tok" sound when I turn off the engine. What would that be?
Reply #33 on:
August 16, 2012, 07:00:41 AM »
Hard to guess... Have you tried the same thing? Turning the crank back and forth to see if there is a bad bearing?
Maybe a sticking clutch pad returning? Worn slide bushings on the Var?
ill_eagle94
Jr. Member
Reply #34 on:
August 16, 2012, 08:00:05 PM »
LOL @ the Supercharger. I don't think the engine has enough power to turn a supercharger. It takes power to make power with those.
2011 Kymco Super 8 2t
2012 Honda Fit Sport
bahiano
Newbie
Reply #35 on:
August 16, 2012, 08:10:57 PM »
Crankshaft bearings seem ok, i moved the crank back and forth.... no play or click so far...it began after exchanging the camshaft (Naraku Touring)
Is there a different Valve adjunstment needed because of the Naraku Camshaft?
Reply #36 on:
August 18, 2012, 02:23:01 AM »
I would suspect yes. Try going to .004 se if that quiets it down. You can try different closer settings till you find the best one or contact the seller/maker.
Back
