Author Topic: Gas/fuel guage reads full all the time  (Read 1443 times)
The Rookie
« on: July 18, 2012, 10:54:46 AM »
As per title, the fuel level gauge reads full all the time, even after over 100miles of use when I could put nearly 5L(1 imp gallon, 1.2 US gallon) in.....float bowl moves freely and it reads full even if I hold it down - any thoughts?
Re: Gas/fuel guage reads full all the time
« Reply #1 on: July 18, 2012, 12:07:15 PM »
the ball in the gas tank is stuck on full.there a ball that floats in the tank that tells you how much gas you have. You may try sticking something in there to free it up but be carefull if it wont come free with a little tug just let it be.
The Rookie
« Reply #2 on: July 18, 2012, 01:37:54 PM »
Sorry, by float bowl I meant the ball in the tank......so nope not that stuck at all.
streido
« Reply #3 on: July 18, 2012, 02:18:54 PM »
Bad sender? Not sure where the sender is tho.
Chaos is my co-pilot.
The Rookie
« Reply #4 on: July 18, 2012, 08:32:54 PM »
Yes looks like a tank out job to access the sender although I haven't had the rear panels off.....
« Reply #5 on: July 18, 2012, 10:05:24 PM »
the sender sits on top of the tank . its a pain to get to because of all the plastic.
its better to just keep a eye on how much gas in in the tank.
baddi
« Reply #6 on: July 18, 2012, 11:50:31 PM »
Once you get the trick, the plastic can be removed in a couple of seconds after removing the 4 screws keeping it in place. ;)
« Reply #7 on: July 19, 2012, 12:49:03 AM »
once you see the plastic off your bike you might not wana put it back on. make a ruckus.........
The Rookie
« Reply #8 on: July 19, 2012, 07:56:33 AM »
Had the rear panels off once already, annoyingly it was fine when we bought it just 100miles ago!
REDKYMCO
« Reply #9 on: July 19, 2012, 07:59:08 AM »
Does the needle come down once you turn engine off???
IF IT IS NOT BROKE DONT FIX IT:)
The Rookie
« Reply #10 on: July 19, 2012, 11:14:35 AM »
Yes, power off it goes to zero...
« Reply #11 on: July 19, 2012, 12:57:27 PM »
check your fuse.
