Author Topic: Trailer size  (Read 2385 times)
Mike2423
Trailer size
« on: July 22, 2012, 10:17:23 AM »
Will a kymco 500 side by side fit on a 5x8 trailer thanks in advance also should I get the efi version or a carbarator version thanks in advance
rlhild77
Re: Trailer size
« Reply #1 on: July 23, 2012, 02:09:51 PM »
I don't think a 5x8 will be large enough.  It would be close.  If you can get the EFI, it is worth it.
Blue500SEi
  • 2012 UXV 500SEi all stock
Re: Trailer size
« Reply #2 on: September 30, 2014, 09:54:07 PM »
Great Question!  I own a UXV 500SEi.  It is 62 inches wide!  At the outside of the rear wheels.  Website says 59"
Blue500SEi
Re: Trailer size
« Reply #3 on: September 30, 2014, 10:02:12 PM »
I should have measured more carefully.  I looked UXV500 up on the website and took a rather casual measure measurement across the front wheels.  Than I bought a 5' x 10' steel sided utility trailer with a ramp.
Upon driving my UXV 500 up the ramp I discovered that the rear wheels were too wide.  You'll need 62 inches inside width to avoid scuffing the side walls of the rear tires.  I had measured the trailer and it came in just over 60 inches but in no way was that enough to drive it on.  Had to exchange the trailer for a 6'x 10' model (Diamond C)
hope this helps you out.
