Author Topic: acceleration lagg  (Read 1448 times)
davisX500
acceleration lagg
« on: July 22, 2012, 10:42:21 PM »
Yesterday I took out my 250 scooter . Everything seemed fine for the first three miles I drove (which is a gravel road) then once i got to the black top she would only do about 50 mph i kept up this speed while toying with the throttle and all at once boom she kicked in and i was doing 75-80 . so i thought addjust the throttle cable which was loose as i found out but didnt solve the problem. any ideas? i was told check the accelerator pump but have no idea how to know if its bad . well it seems to kick in as soon as i hit 50 mph on the dot. I am soooo lost.
ce
Re: acceleration lagg
« Reply #1 on: July 23, 2012, 12:40:38 AM »
sounds like your diaphragm has a hole in it, that's very common on the Xciting 250
I got a new diaphragm from Stadium Yamaha after I opened up the carb and found it had a slight tear in it so that itwould not lift the slide all the way up
I repaired it with some goop until the new one arrived, red gasket maker, but don't goop it  on too much, and replace it at once
Check and see  if that's it, two screws on top of the carb
Albuquerque, New Mexico
davisX500
« Reply #2 on: July 23, 2012, 03:48:26 AM »
Thank you!!!!! I looked at the carb valve assy piston and the diaphragm on it had a small tear. sealed it and hope to get a new one asap. going to go for a ride tomorrow and see if it fixed the problem. Again thank you ;D ;D ;D :D :D :D :P
« Reply #3 on: July 23, 2012, 05:21:27 AM »
how did you seal it?
davisX500
« Reply #4 on: July 23, 2012, 06:12:03 AM »
i used a plyable gasket maker got it in the tear with a thin layer on either side. just hope it holds cheapest one i have found is 55$ online hard to find parts online.
« Reply #5 on: July 23, 2012, 06:17:30 AM »
hmm...silicone
Would goop work?
ce
« Reply #6 on: July 23, 2012, 01:42:25 PM »
That looks like the sh**, Vivo, I bet it would work great, but Zombie sez not to use that sh** in the carb, cuz it'll get sucked down in and funt it all up.
He thinks we're using big wad gobs of it, wiped all over, but we just used a teeny tiny bit, he don't know, oh sh**, here he comes, put that sh** away...
What?
« Reply #7 on: July 24, 2012, 02:17:45 AM »
..zombie likes big gobs of sh**...schtuff...and goop and stuff...lol...
                                   ;D
« Reply #8 on: July 24, 2012, 02:23:19 AM »
 ::) ::) ::) wasn't me....
Shh...  I use Goop all the time...for every f*cking repair... household goop, shoe goop, automotive goop... one hundred percent satisfacshun... Zombie? he might be using marine goop for all we know...
here's another stuff I use to rebuild engine mounts ,,, 3m window weld urethane....
« Reply #9 on: July 24, 2012, 02:25:11 AM »
..marine goop...
..semper fi....
davisX500
« Reply #10 on: July 24, 2012, 05:48:22 AM »
well the silicon blew out but my shoe goo $uck yeah did the job we are back in business
