Did you miss your
activation email
Scooters - 50cc
back tire..........
Topic: back tire.......... (Read 1750 times)
back tire..........
July 28, 2012, 07:36:14 PM »
when my scoot is at idle and up on the center stand there is a little rattleing comeing from the tire hub.
is it the wheel bearings or could be a sign that its low on gear oil. When I take my hands and move the tire left to right just a very little it gos away. ya I know the tire should not move left to right at all. its not much just a very little. Also when the scoot is off the center stand it goes away. What might it be and should I worry about it.
skippy
Sr. Member
Re: back tire..........
July 28, 2012, 07:47:25 PM »
has old blue broke something should have put a 20 on you braking the wheel.
i think most scoots have a little play in them side to side. could be wrong though. could be a the wheel berings on there way out or just a little dirt.just gives you an excuse to strip down and have a play.
whiteknight
..Knight Tweed..
July 28, 2012, 11:41:19 PM »
i know my back wheel has a TINY amount of play in it but i dont have any rattling noises. havnt really worried about it. if i was to worry about every noise my scoot made i wouldnt ride it.
undead primate
Reply #3 on:
July 29, 2012, 12:29:27 AM »
+1
..well, for pete's sake!!..check the gear oil, and eliminate that factor...lol..
..you should not be able to move your wheel, when facing it from the rear, any perceptable amount left to right...
Reply #4 on:
July 29, 2012, 01:21:35 AM »
Gear oil is good . Ill just ride it and see what happens.might not be anything.
undead primate
Reply #5 on:
July 29, 2012, 01:25:50 AM »
..but, blue...if you indeed CAN move your wheel side-to side, from behind...there issa problem...
..dont get stuck out somewhere on th road...aint much fun in 90+ degree weather...
Reply #6 on:
July 29, 2012, 03:09:33 AM »
after I changed the gear oil I also gave the Nut that holds the back tire on a good tug it did go thighter a little so maybe that was it. I will just ride to work which is a short distance to see how it holds up.
undead primate
Reply #7 on:
July 29, 2012, 03:29:31 AM »
..i knew a girl one time that could tug good on a nut...
Reply #8 on:
July 29, 2012, 09:24:58 PM »
Took the scoot to work today. And when I got home I noticed noise again. if its something with the bracks would they rattle at all.
streido
I view speed limits as guidelines rather than laws
Reply #9 on:
August 04, 2012, 07:45:50 PM »
Could it not just be the brake shoes rubbing on the drum?
Chaos is my co-pilot.
Reply #10 on:
August 04, 2012, 11:32:55 PM »
Quote from: streido on August 04, 2012, 07:45:50 PM
after rideing for a few more days the sound went away mmmm dont know what to think.
a guy at the scoot shop I go to things it might be the spring holding the bads came lose or broken.
I heve the springs just need to get brave to touch my scoot lol.................I have done brakes befor so I think ill be alright.
Back
