Author Topic: Clutching SOLVED!!!  (Read 2480 times)
sbveenker
Clutching SOLVED!!!
« on: August 01, 2012, 05:20:15 AM »
So many of you might have this same problem so I thought I would let you in on a little discovery we found. We (Powerhouse Motorsports) have been having a lot of UXVs coming in with clutching issues. All of the machines we have worked on have had a lot of dust and dirt build up in the clutches cause the oem weights to get flat spots or the aftermarket epi rollers to actually crush cause the clutches not to work correctly.  Well we finally found the solution. We have come up with an awesome clutch kit that gives you way better low end as well as faster top speed (48 mph without hitting the rev limiter at about 4500 ft). This kit also gives you the perfect clutching for steep mountain riding. If you'd like more info on this kit feel free to call us at Powerhouse Motorsports 801-785-2244.
