Author Topic: Electric Starter  (Read 997 times)
CharlieP91
Electric Starter
« on: August 02, 2012, 01:41:37 PM »
ok so Im new to the forum and this is my first post !
I recently bought an Agility 50, it's great except the electric start does not work, so I have to kick start every time. This isn't a big problem as it usually starts first time but I would like an electric star and was wondering if anyone knew of a better electric start to put on it as I know kymco's are know to have problems with the electric starts.
thanks!
REDKYMCO
Re: Electric Starter
« Reply #1 on: August 02, 2012, 05:00:43 PM »
Does the electric start do anything when you press the button???
IF IT IS NOT BROKE DONT FIX IT:)
CharlieP91
« Reply #2 on: August 02, 2012, 05:20:40 PM »
it doesn't no. once it made a sort of spluttering sound but never again since
skippy
« Reply #3 on: August 02, 2012, 05:37:24 PM »
check the connection to the starter motor. its a little black plug under the carb. i had the same prob untill i found the plug was lose and was alittle green on the contacts clean the contact points up and push the plug back on.
CharlieP91
« Reply #4 on: August 02, 2012, 05:53:33 PM »
ok great. il check that tonight and post the results. thanks for the quick reply !
« Reply #5 on: August 03, 2012, 01:54:51 AM »
make sur the battery has a good charge also.
skippy
« Reply #6 on: August 08, 2012, 07:04:50 PM »
CharlieP91
 any update on the electric start?
