Author Topic: Exhaust system troubles??  (Read 2267 times)
venoxicated
« on: May 28, 2009, 01:55:00 AM »
I recently removed the baffles from my exhaust and now it's running extremely rich.  I was told that it might run lean once I removed the baffles, and it has my mechanic a little "baffled" (pardon the pun).  Can anyone enlighten me as to  what might be the problem.  It's like it begins to "load up" at about 30 mph, and gets worse the longer it runs.  Is there anything in the carburation that needs to be  looked at?  I'm open to suggestions.  thanks much.
obxbiker
  • ADMIN/SITE BUILDER @ www.piwyr.co.cc
Re: Exhaust system troubles??
« Reply #1 on: June 24, 2009, 08:06:37 PM »
You NOW need to change the 'jets'.
pops @ http://piwyr.co.cc can give you the details.
Venox info @ www.piwyr.co.cc
2003 (3) Super9 LC's heavly modified........
2004 Modified Venox ''OBnoXious Nox'' ......
2006 ''Yellow NOX''.......
