The stock were 20x12mm, 15.5gr, went to 14gr sliders (-10% as recommended by Dr Pulley guys).
The multivar weights are 23x18mm, got it with 20gr weights which makes the bike ride up the
redline all the time, so I bumped it up to 23gr (wanted 24, wasn't available).
Extremely happy with the results now, got low revs cruising around, and it'll still rev to almost
redline when you open it up completely (7500, and was 5500 stock, 6500 with pulleys in stock cvt).
Good thing is I still get 500 revs less at speeds above 65mph (compared to stock), and it'll still
accelerate faster then any other setup.
Using the stock contra-spring all the time.
The weight depends on what you're trying to do.
Just bare in mind that using the same weight of pulleys as your stock rollers will keep the revs
at the same spot up to about 2/3 of available top speed, and then it'll begin to drop A LOT, which
can result in lower top speed (or more time to get there).
This happened to me going from 15.5gr to 14gr, lost about 2-3mph, but the revs were a lot lower.
