Author Topic: Heavier Bar ends on Yager....  (Read 1673 times)
ludo
« on: August 05, 2012, 06:44:09 AM »
Since day one, I found that the Yager is quite light on the front end (maybe because I am used to heavier scooters).
I started noticing some wobbling after adding a topcase. I decided to install those Jettin Industries bar end weights I had left from another scooter.
After a lot of hand filing and shopping for metric screws, I got them on.
The front end is now MUCH more stable, precise and almost vibration free.
For info, the OEM bar ends are 195 and 220 gr. vs 495 gr each for the new ones.
« Last Edit: August 06, 2012, 07:53:53 AM by ludo »
Kymco Yager GT200i -
Totally awesome machine with anti-theft styling ;D
ludo
Re: Heavier Bar ends on Yager....
« Reply #1 on: August 05, 2012, 06:44:49 AM »
Heavy bar ends vs OEM
« Last Edit: August 06, 2012, 07:55:16 AM by ludo »
az_slynch
  • Tucson, AZ
« Reply #2 on: October 30, 2012, 05:54:08 PM »
Thank you for the tip! I have found that the stock ones are a bit light as well. Time to find heavier bar-ends.
'01 Super Fever ZX 50
'05 Bet 'n Win 250
'10 Yager GT200i
'12 Yager GT200i
'16 K-Pipe 125
'18 Spade 150 stolen April 2020
ludo
« Reply #3 on: October 30, 2012, 07:08:09 PM »
You're welcome.
Post your pics when you add some.
az_slynch
  • Tucson, AZ
« Reply #4 on: November 21, 2012, 06:23:31 PM »
Ludo,
     When you fitted your Jettin bar-ends, did you re-use the mounts already installed in the handlebars? They seem quite firmly entrenched in there.
     I bought some 14.2g stainless bar-ends from HVMP.com, but I will require a different bolt and a touch of re-machining to make them work OK. Nothing that a quick spin in a lathe can't fix.
     http://www.hvmp.com/universal.htm
« Last Edit: November 21, 2012, 06:25:12 PM by az_slynch »
'05 Bet 'n Win 250
'10 Yager GT200i
'12 Yager GT200i
'16 K-Pipe 125
ludo
« Reply #5 on: November 21, 2012, 09:14:18 PM »
Ludo,
I bought some 14.2g stainless bar-ends from HVMP.com, but I will require a different bolt and a touch of re-machining to make them work OK. Nothing that a quick spin in a lathe can't fix.http://www.hvmp.com/universal.htm
Hey Az!
Yes, I re-use the same mounts.
The problem was that the Jettin weights came with a M6 screw and the mounts on the Yager are M8 size.
So I drilled in the weights and got some longer and bigger screws. I also added some washers on the throttle side since the mount is recessed.
Hope that everything makes sense.... ;D
MVP makes some great products.
You will definitely feel the difference with those weights (14.2 OZ maybe?)
Good luck and post your results!
