Author Topic: venox wont start  (Read 6707 times)
kpolykarpou
venox wont start
« on: August 06, 2012, 04:06:29 PM »
hi again guys
i really have problems with my venox
it is very difficult to start.
until now i changed 2 times the cluch of starter. also the sliders, the timing chain ..............
i really dont know
i bought an fz6 now, but i want to repair it and sell
max oradea
Re: venox wont start
« Reply #1 on: August 09, 2012, 03:28:22 PM »
difficult starting... usually means carb. problem. only  thing you can do is open the carbs and clean them up and see if it works... pull the plugs and check before if its getting enough gas or too much gas.
kpolykarpou
« Reply #2 on: August 11, 2012, 07:57:08 PM »
Thanks, but, unfortunately I ve already done that
Carol
  • Brainerd, Minnesota
  • Look me up on facebook !
« Reply #3 on: August 12, 2012, 07:37:19 AM »
Hubby had a starting problem with his Venox, hauled to the shop........it was something to do with the spring in the gas cap. Hasn't had any problems since. It has been a great bike overall. He just clicked over 26K (06 Venox, canary yellow).
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body. But rather to skid in broadside , thoroughly used up , totally worn out and loudly proclaiming "WOW, what a ride!!"
max oradea
« Reply #4 on: August 13, 2012, 05:39:42 AM »
oh you mean this vacuum block because the gas tank is not vented... have a look see if the fuel valve is also blocked too.
kpolykarpou
« Reply #5 on: August 13, 2012, 07:07:11 AM »
sorry guys
i hae checked these too
i don t know
the  noise is like a tak tak noise.
ce
« Reply #6 on: August 13, 2012, 06:44:38 PM »
Did you check the valve gaps when you were in there for the timing chain?
Albuquerque, New Mexico
kpolykarpou
« Reply #7 on: August 17, 2012, 09:33:47 PM »
i think its sth of the pistons .
the one cylinder has less compression tha the other
Paperkrain
« Reply #8 on: August 19, 2012, 11:18:08 AM »
Hi
I hope this helps. This is from the service manual for the Venox 250.
Regards,
JB
bubbarowley
« Reply #9 on: September 29, 2012, 02:36:19 PM »
So is it just turning over and over and not starting?
max oradea
« Reply #10 on: November 30, 2012, 07:12:40 PM »
Tak tak and no broom, battery is dead or not charged. Try charging or replace. For a differential diagnosis try a jump start. From a car. From what you are saying I supposed you mean it is not turning over the engine. Battery should have 12.3 or above for a good start.
thomestayler
« Reply #11 on: March 08, 2013, 09:51:36 AM »
I completely understand your difficulty to starting about your Venox bike and I want to suggest you that your bike really need to fix this problem if you run it properly. I want to suggest you than if you found any Venox centre near you than immediately take your bike to that service centre. So, they might be help you to fix your Venox bike starting issue accurately.
kpolykarpou
« Reply #12 on: August 04, 2013, 08:16:10 PM »
I had the same problem. And still didn't find out what was the problem. I bought a new bike
kpolykarpou
« Reply #13 on: August 06, 2013, 08:11:26 PM »
cors50agility
« Reply #14 on: August 18, 2013, 11:17:56 AM »
You double threaded your problem , it must be upsetting :)
