Author Topic: Battery tender  (Read 4136 times)
big blue
Battery tender
« on: August 15, 2012, 07:51:16 PM »
Hello all, I was wondering if it is possible to connect a Deltran Battery Tender to the accessory plug located in the glove box on my 200i lX. Is that plug for power out only or is it a two way connection? I plan on getting a Battery Tender soon and I know that a cigarette lighter type plug is available. Any ideas? ???
« Last Edit: August 15, 2012, 10:55:33 PM by big blue »
fshfindr
Re: Battery tender
« Reply #1 on: August 15, 2012, 08:09:26 PM »
That's what I do.  It's easier than accessing the battery and it works just as well.
Richard L.   :)
Richard L. in Bellmawr
big blue
Re: Battery tender
« Reply #2 on: August 15, 2012, 10:44:54 PM »
Thank you for the quick reply I'll check it out. ;D
Dolemite
Re: Battery tender
« Reply #3 on: August 16, 2012, 09:45:12 PM »
I thought the accessory port didn't work when the scooter was turned off. Keeping you from draining the batter if you have something plugged in.
So the tender jr. adapter WILL work?
TroutBum
  • 2012 Like 200i (sold)
Re: Battery tender
« Reply #4 on: August 16, 2012, 11:03:11 PM »
I use the ring wire harness and let the connector hang out the bottom near the kickstand. This allows easy access for connecting up the tender and I don't need to have the glose box remain open.
big blue
Re: Battery tender
« Reply #5 on: August 17, 2012, 01:58:19 AM »
I really don't know about whether the accessory jack is usable with the key off. What I want to know is can the port be used to sustain the battery during storage by plugging the battery tender into it? If the key is off then the port SHOULD allow power to flow back to the battery via the recharger. Am I wrong? I'm not an electrician! :-\
SonicSix
  • 2012 Like 200i
    • My Scooter Site
Re: Battery tender
« Reply #6 on: August 17, 2012, 12:45:44 PM »
With the key off, test the outlet.  If it has juice, then you can use the tender with it.  If it has no juice, then it will not work.  An incomplete circuit won't let electricity flow in either direction, period.
2012 Kymco Like 200i Black and Blue
White Bell Revolver EVO Modular Helmet with Dark Smoke Shield
States I have scootered in...
big blue
Re: Battery tender
« Reply #7 on: August 17, 2012, 03:27:53 PM »
I'll try it.
big blue
Re: Battery tender
« Reply #8 on: August 17, 2012, 08:06:38 PM »
Right you are, the socket is NOT energized with the key off. Thanx for the info.
fshfindr
Re: Battery tender
« Reply #9 on: August 18, 2012, 06:00:39 PM »
The acc port will work without the key if it was installed by yours truly.  It did not come with my Yager.  The only thing between the battery and the acc is a fuse.
Richard L.
« Last Edit: August 18, 2012, 06:02:25 PM by fshfindr »
MassScoot
Re: Battery tender
« Reply #10 on: August 26, 2012, 12:34:36 PM »
I'll try it.
Big Blue: I don't have a Like 200i, I own a GT300i. Anyway...Just attach the pigtail directly to the battery & snake it thru. Took me like 15 minutes to get this done my my GT300i. You could use a little die-electric grease on the ends of the pigtail to prevent corrosion. A tube can be had @ Lowes/Home Depot for like $3.00
http://www.amazon.com/Battery-Tender-021-0123-Junior-Charger/dp/B000CITK8S/ref=sr_1_1?ie=UTF8&qid=1345984263&sr=8-1&keywords=battery+tender+jr.
If you have a seasonal scooter season like me, just pull you battery out & keep it on a float charge in the Winter months. Trust me....I small $25.00 investment could keep your battery going for years!
« Last Edit: August 26, 2012, 10:14:57 PM by MassScoot »
Gloucester, MA. (Home of the Perfect Storm)
2012 Silver Kymco GT300i (Biondi Windshield/Shad SH40 Cargo Topcase)
2015 White Honda PCX150 (Shad SH37 Topcase)
2013 Yellow Lance PCH125 (Shad SH33 Topcase)
big blue
Re: Battery tender
« Reply #11 on: August 26, 2012, 04:31:15 PM »
Thanx for the reply MassScoot. I plan on getting one before Fall sets in. Weather here in Oregon gets nasty after October but not like east coast. I'm originally from Mass/RI .
MassScoot
Re: Battery tender
« Reply #12 on: August 26, 2012, 10:14:02 PM »
Big Blue: You're a New Englander like me? I'm sorry I meant to say a $25.00 investment, not $35.00! I had a buddy of mine that lived in the Eastern part of Oregon & he said it got pretty nasty there in the Winter. I'm glad you'll pick-up a Battery Tender, it's so worth the short coin! Good Luck.
« Last Edit: August 27, 2012, 09:51:36 PM by MassScoot »
