Did you miss your
activation email
Scooters - 125 to 300
Agility 125
Torque Value for Oil Drain Plug and Oil Screen Bolt
Topic: Torque Value for Oil Drain Plug and Oil Screen Bolt (Read 1799 times)
Jim Moore
Jr. Member
August 15, 2012, 09:09:10 PM »
I'm changing my oil. The manual says about 1.0 kg-m for both of those bolts, which translates to about 7 ft-lbs. That doesn't seem like much. Any thoughts?
Thanks,
fshfindr
Re: Torque Value for Oil Drain Plug and Oil Screen Bolt
August 15, 2012, 11:38:55 PM »
This should help. It is from DINK (Yager) 200i/125 service manual. I'm sorry about the size but attaching is a little tight. You should be able to make it bigger. (Engine oil & gear oil drain plugs are 18 ft lbs)
Richard L.
Last Edit: August 15, 2012, 11:50:08 PM by fshfindr
Richard L. in Bellmawr
Jim Moore
Jr. Member
August 16, 2012, 11:19:23 AM »
That sounds more like it. Thanks.
Back
