Author Topic: Which grease are you using on your torque driver?  (Read 2698 times)
wassonii
  • Death needs Time for what it kills to grow in -wsb
« on: August 16, 2012, 05:16:59 PM »
Hi all. I recently pulled apart, cleaned, and regreased my torque driver (OEM), but am having second thoughts about the grease I used. Valvoline Multi-purpose Automotive and Industrial. It's only been a few weeks, so no damage done, but I want to get a feel for what others are using with good results.
I found on ZumaForums this thread http://www.zumaforums.net/phpBB3/viewtopic.php?f=57&t=17831&sid=4ae18a8b7751e4a5c5ca09e88e0a264a and although the pics are from some fellow's first attempt (and waaaaay too much grease), there are some products named, such as Amsoil Series 2000 Synthetic Racing Grease, Bel-Ray Waterproof Grease, Sta-Lube SL3190 Red Extreme Pressure Grease.
There's a good "how-to" over at 49cc http://49ccscoot.com/tqdriver.html
Batman has a good 'how to' http://www.kymcoforum.com/index.php?topic=3111.0
Thanks in advance!
sans scooter, rien
axy
Re: Which grease are you using on your torque driver?
« Reply #1 on: August 16, 2012, 07:35:50 PM »
Graphite or teflon - based, but any "general purpose machinery grease" will work.
Kymco Agility 125 2008
wassonii
« Reply #2 on: August 16, 2012, 08:14:26 PM »
Right on. I wasn't sure if one type or brand lasted between cleanings better than another, but the lubing qualities of the types you mention definitely make more sense. Thank you!
sans scooter, rien
streido
« Reply #3 on: August 16, 2012, 09:09:34 PM »
I tend to use the same grease i use for bearings on mine now, Lithium based high melting point grease, tho i have used Rocol Dry Moly Paste in the past.
Chaos is my co-pilot.
« Reply #4 on: August 16, 2012, 09:44:23 PM »
..been using a general purpose red grease of late, but then i'm in mines about once a month anyway...
..like today, for instance....
wassonii
« Reply #5 on: August 16, 2012, 10:05:33 PM »
I've been in my clutch several times the past few weeks, trying out springs with weights, but han't gone into the td in a coupla weeks. I'm having a time finding a U.S distr. for the Rocol Dry Moly since Streido mentioned it.
sans scooter, rien
streido
« Reply #6 on: August 17, 2012, 08:33:28 AM »
I only used it cos i "borrowed" a can from work, normal bearing grease is fine and easier to clean off the excess. That moly paste is some messy sh** to clean off once its on unless you have cleaner. I wouldnt buy it, i just used it cos it was free and i had it at the time and had no bearing grease. Still worked tho for me at the time.
wassonii
« Reply #7 on: August 17, 2012, 01:30:17 PM »
I don't need any help making messes ;D
Napa auto parts apparently has some manner of dry moly, but I'll be getting some Lucas Oil grease in a tube.
Apparently, the Valvoline is rated to just under 300 degrees, while the Lucas oil grease is between 500-540, depending on whether I get the tacky or the heavy duty.
sans scooter, rien
