Contra spring will change everything. I run a red contra myself. I'm around 7 or 8g rollers right now. But, I have a people 50 2t. Not sure if they have the same engine or not. Probably doesn't make much difference anyway.
Your mid range issue may be of because of the needle setting in the carb. Unfortunately the needle is not adjustable in the stock carb. You can find a way to shim it. Wordslinger has. He does it by using aluminum from beer cans to shim the needle up
![Cheesy :D](https://www.kymcoforum.com/Smileys/default/cheesy.gif)
. I never found a way to get the needle out of the plastic retainer myself. I was afraid I was going to break it.
I weigh about 275 lbs, so I don't think that's the issue
Yeah I think you're lean.
I think. I'm not sure. Like I said lots of variables.
What was the factory size? Where do you live? altitude? climate? Mine was really small. Like 75 or something like that.
You can not go by what the spark plug looks like. You have to do plug chops. This involves warming the engine up, installing a new plug, and starting it, then immediately running it wide open for a mile or two. When you're done, kill the ignition while keeping the throttle wide open. Let the engine come to a complete stop before letting go of the throttle. Pull the plug and look at the white insulator inside. You want a coffee(cream coffee) color on that insulator. There will be a ring of coloration. The distance from the tip also indicates fuel air mix. You can cut the threads off to get a better look(hence the name "plug chop") Here is a good link
http://www.kawtriple.com/mraxl/carb/plugchop.htmThere is three ranges you need to check. Idle, mid range and full throttle. Idle is controlled by an idle/slow speed jet as well as the mix screw on the carb. The mid range(1/4 to 3/4 throttle) is controlled by the height of the needle as I mentioned earlier. Last, full throttle(3/4 to WOT) is controlled by the main jet. Much more to it than my brief break down so do some research. You can read for days on tuning a carb properly.
