Author Topic: Polini big bore kit for 2011 super 8 50 2t  (Read 12416 times)
Geehun
Re: Polini big bore kit for 2011 super 8 50 2t
« Reply #15 on: August 19, 2012, 05:32:53 AM »
alright i'll be patient and do a little bit more research.
btw i live in vancouver, british columbia.
Peters
  • In Glock I Trust
« Reply #16 on: August 19, 2012, 05:38:35 AM »
Gotcha. So cooler climate. Cooler generally means bigger jets. Cool air is dense air. Dense air means more oxygen. More oxygen means more fuel.
Higher altitude will offset this. Higher altitude means less oxygen, ect...
*2001 ZX-50 beater
Peters
  • In Glock I Trust
« Reply #17 on: August 19, 2012, 05:43:50 AM »
Humidity has a lot to do with jetting too
I pretty sure higher humidity means smaller jetting
*2001 ZX-50 beater
Geehun
« Reply #18 on: August 19, 2012, 10:21:01 PM »
alright just bought a set of 9 clutch springs, set of 3 contra springs, some 9 gram rollers and some 9.5 gram rollers. Once they arrive and installed, i will update you what happens.
Geehun
« Reply #19 on: August 20, 2012, 12:44:59 PM »
Hey Peters, i have some more questions.
Going to run red clutch springs with red contra springs and some 9 or 9.5 gram rollers. Exhaust will be changed soon maybe to technagis or stage 6. What carb should i purchase? Can you send or share a link?
Once i get the bigger carb, would jets have to be changed? or it's adjustable? It's a bitch changing the jets on the super 8's.
I'm looking for faster acceleration to reach my top speed quickly. With the bigger carb and exhaust, what would i gain?
Thanks
Peters
  • In Glock I Trust
« Reply #20 on: August 20, 2012, 03:46:39 PM »
Here is a 19mm carb kit. It's a Dell Orto. One of the best carbs you can get. Has adjustable needle. Comes with everything you need. Uses 5mm main jets.
http://www.racingplanetusa.com/carburetor-malossi-phbg-19mm-kymco-sf10-p-314-1.html?cPath=2_21356_21358&sessID=0b7a6bfa6ae6650a1fc6b723da4d6e62
The jets have to be changed. You don't have to completely remove the carb though. I just take the bolts out and turn it sideways just enough to remove the bowl. Once you get it dialed in, you really don't have to mess with it too much.
Here are the rest of the carbs on Racing Planet, as well as main jet sets and individual jets. I'm not going to promise you this is the cheapest place to buy the carb/jets. You'll have to shop around. Just remember that link is to the kit, not just the carb. Finding all the adapters and cables would be a pain in the ass. Better to just get the kit. If you do decide to order from Racing Planet, call and mention the forum. You should get a discount.
http://www.racingplanetusa.com/index.php?shop_ID=1&sessID=0b7a6bfa6ae6650a1fc6b723da4d6e62&olevel0=2&olevel1=21356&olevel2=21362&level0=2&level1=21356&level2=21358
Bigger carb and exhaust will really open up that bbk. Just remember you're changing the hp and torque curve so you'll need higher rpms to take full advantage. This may involve changing the rollers again.
« Last Edit: August 20, 2012, 03:50:46 PM by Peters »
*2001 ZX-50 beater
Geehun
« Reply #21 on: August 21, 2012, 05:49:26 PM »
Just ordered myself a techigas rs 2 exhaust. Going to pass on the carb. Just realized I keep gassing up a lot. A bigger carb means more hp and more gas guzzling
Peters
  • In Glock I Trust
« Reply #22 on: August 21, 2012, 06:23:20 PM »
Also means better cooling of the cylinder/piston and better atomization of the fuel meaning more efficient burn of the fuel and overall a longer lasting engine. I know it sucks you have to pour so much money into it but, you really should get a larger carb.
*2001 ZX-50 beater
Peters
  • In Glock I Trust
« Reply #23 on: August 21, 2012, 06:28:56 PM »
I see now that Racing Planet is out of stock
It's the same kit as the people 50 2t
I'm doing a little searching right now
*2001 ZX-50 beater
Peters
  • In Glock I Trust
« Reply #24 on: August 21, 2012, 06:38:23 PM »
Read this thread:
http://www.kymcoforum.com/index.php?topic=7083.msg76710#msg76710
Josh(Areomyst) hooked stljimmy up with a kit. Likely cheaper too. I'm sure he'd help you out. Reply to that that post and/or send him a PM. He is very knowledgeable when it comes to scooters. He will tell you if you really need a bigger carb.
*2001 ZX-50 beater
Geehun
« Reply #25 on: August 27, 2012, 06:53:53 AM »
ok my set of contra and clutch springs should arrive tomorrow. I already bought an electric impact wrench which was on sale. Peter would you know what size socket i should get to remove the clutch?
Thanks.
Peters
  • In Glock I Trust
« Reply #26 on: August 27, 2012, 06:55:54 AM »
14mm for the clutch/rear pulley
17mm for the variator
*2001 ZX-50 beater
Peters
  • In Glock I Trust
« Reply #27 on: August 27, 2012, 06:58:51 AM »
Oh, and you may have to have somebody hold the rear brake while you loosen the nut. I usually just hold the tire with my feet. Works pretty well. Same thing when you go to loosen the variator. Except you have to put your feet on the variator itself.
*2001 ZX-50 beater
Geehun
« Reply #28 on: August 27, 2012, 08:01:11 AM »
Thanks for the info.
Geehun
« Reply #29 on: September 01, 2012, 08:50:07 AM »
Ok exhaust came. Removed the restrictors inside. Installed malossi 8.5 rollers followed with red contra and clutch springs. Top speed on flat is 80km/h. Very steep hill from bottom to top, accelerates without hesitation and max speed is 70km/h. Downhill top speed is around 95km/h as per my gps. Exhaust is super loud.
Not running into any issues. No lag nor bogging issues.
