Author Topic: Polini big bore kit for 2011 super 8 50 2t  (Read 12405 times)
Geehun
Re: Polini big bore kit for 2011 super 8 50 2t
« Reply #45 on: September 09, 2012, 07:22:50 PM »
I turned it in all the way and backed out 2 full turns. And then I just adjusted the speed big screw and happy with what I got.
« Reply #46 on: September 10, 2012, 05:17:02 AM »
Fine tune it a bit more. Try 1/4 turn increments. That will get it Purrfect.
Wish we could fix politics...
Geehun
« Reply #47 on: September 10, 2012, 06:23:53 AM »
just thought you guys might want to take a look. =)
« Reply #48 on: September 10, 2012, 06:26:38 AM »
Love that MR2  8) 8) 8)
Peters
  • In Glock I Trust
« Reply #49 on: September 10, 2012, 06:30:35 AM »
Awesome!
Very nice S8
Geehun plate  ;D
Are you in NC?
*2001 ZX-50 beater
« Reply #50 on: September 10, 2012, 06:33:31 AM »
Nice toys. for sure.
Geehun
« Reply #51 on: September 10, 2012, 06:58:38 AM »
it's an 1989 mr2 fully restored with original engine. Not rebuilt.
Original red paint job.
4agze engine with cusco pulley kit ( was boosting 8psi, now 14psi ) belt has to changed every year due to oversized pulley.
d2 sport 26 point tension adjustment coil overs
hks sport exhaust
hks cams
Yes! it's a geehun custom plate. I'm from Vancouver, British Columbia, Canada.
Since you guys like the mr2 i'll upload more pics.
« Reply #52 on: September 10, 2012, 07:03:42 AM »
clean solid lines indeed..... ;)
Pimpy1
  • Mo Hoes Power
« Reply #53 on: September 10, 2012, 01:42:10 PM »
I like the look of lowered cars but it sucks being so low you have to drive around beer cans so they don't get stuck under the car.
2011 Kymco Super 8 2t
2006 Kymco People 250
« Reply #54 on: September 11, 2012, 01:22:57 AM »
Pimps don't like lowered cars of course.... ;D
Pimpy1
  • Mo Hoes Power
« Reply #55 on: September 11, 2012, 03:48:20 AM »
No, I role more like this.
Geehun
« Reply #56 on: September 11, 2012, 01:52:17 PM »
alright so i did a couple runs on my scoot last night. Had my carb idle mix and idle rpm adjusted again.
When i bought the scoot, after the upgrade to red clutch springs, there used to be a lag before the scoot would take off when throttle was fully opened. With now my idle rpm set a bit higher, i now have no lag from starting from the line. When i completely open the throttle it just goes.
My question is, is there anything wrong with this picture, should i need a bit more adjustment?  Idle rpm is not high enough yet causing the back wheel to spin. Should i tune the speed down a bit or leave it the way it is?
Thanks
Peters
  • In Glock I Trust
« Reply #57 on: September 11, 2012, 05:29:22 PM »
As long as the back wheel doesn't spin(significantly) while on the main stand you should be fine. Just remember it will idle a little higher when it's cold. You don't want it to push itself off the kick stand while it's warming up  :D  ;). Really, you should warm it up on the main stand. I don't though  ;D
I imagine with the red clutch springs the idle would have to be pretty high for that to happen
You never know... Somethin crazy could happen... Like a clutch spring breaking
« Last Edit: September 11, 2012, 05:33:44 PM by Peters »
*2001 ZX-50 beater
Geehun
« Reply #58 on: September 12, 2012, 01:10:48 AM »
ok thanks for the advice.
2nd question, what do i have to tune/install/modify to run open air filter on my stock carb. Thinking of getting a k&n with a water repellent shroud.
Peters
  • In Glock I Trust
« Reply #59 on: September 12, 2012, 01:24:23 AM »
Larger MJ and tune the idle mix again
*2001 ZX-50 beater
