Author Topic: Polini big bore kit for 2011 super 8 50 2t  (Read 12403 times)
Geehun
Re: Polini big bore kit for 2011 super 8 50 2t
« Reply #60 on: September 12, 2012, 01:35:36 AM »
my mj is 85 now. what number or size would you recommend?
Geehun
« Reply #61 on: September 13, 2012, 01:23:25 PM »
Does anyone here own a kymco s8 2 stroke and has an open air filter setup? If so can you share your build with what jet size i should get? I just need the range of jets i would require to run properly.
thebatman
« Reply #62 on: September 13, 2012, 10:39:29 PM »
If you have a 85 in right now, then I would say that you should get 90-125
I'm thinking that a 100-105 should have you right there...(i was using a 90 w/arreche 19mm carb)
        (had a 97 in my oem zx carb)
        (running a 88 in my oem ag now)
"THE BAT"MAN...
Says:
Geehun
« Reply #63 on: September 13, 2012, 11:44:28 PM »
thanks
Geehun
« Reply #64 on: September 25, 2012, 02:05:40 PM »
Hey guys my stuff just arrived.
Just picked up my polini open air filter followed by some jets. The sad thing is, i think the jets dont fit?
The thread is the right size but the one i bought only has 3 thread counts, the stock one has four, Does this matter?
I tried from 92-100 with the 3 thread count jets and everytime i tried to start the scoot, it just doesnt turn over. Am i doing something wrong here?
I'm going to pick up the right main jet size locally to try it out. They're $5 each and the guy only has #92 and #102.  If these jets still dont't work what could be the issue and would SPI carry a jet kit?
batman, zombie, peters? ??? >:(
Geehun
« Reply #65 on: September 25, 2012, 03:11:09 PM »
And just a note to add to above. I tried running opening air filter on my 85 jet. When I open throttle scoot will accelerate and then quickly dip in Hp. Can I also get an elaborate definition of this?
Thanks
LoveMyKymco
« Reply #66 on: October 19, 2012, 03:45:37 PM »
Not sure if you ever figured it out but youre running lean if theres a dip in HP lol. If it sounds like its gurggling out the exhaust its rich, if its quieter than normal its lean if that makes any sense.
