Author Topic: Mods in.... going slower >:(  (Read 13286 times)
Re: Mods in.... going slower >:(
« Reply #15 on: August 23, 2012, 02:04:40 AM »
..well, DO NOT install heavier rollers...
..try 7-7.5 grams...
..well, at least try that...
« Last Edit: August 23, 2012, 02:09:05 AM by wordslinger »
Rage
« Reply #16 on: August 23, 2012, 02:08:30 AM »
Ok, will pick up a few different sets and play around with them. Sucks I can't use that spring tho. Thought the 1500 spring would be ok with a stock setup. Another question, does it matter which way the rollers are installed? One side has more of a lip than the other...... Thanks again.
« Reply #17 on: August 23, 2012, 02:11:29 AM »
..you CAN use that spring...put the 1500 back in and try 7.5 rollers...
..put the more solid side of the roller to the left, if installing on the "top" roller slot in the variator...
Rage
« Reply #18 on: August 23, 2012, 02:14:05 AM »
But if the 8.5s wouldnt open the pulley, how will the 7.5s? Sorry, still learning here.
Peters
  • In Glock I Trust
« Reply #19 on: August 23, 2012, 02:25:11 AM »
Wordslinger and zombie definitely know better than me  ???
Slingers got an S9 too so....
Maybe your new belt is too short
*2001 ZX-50 beater
« Reply #20 on: August 23, 2012, 02:26:23 AM »
..it's all about getting into the good rpms...
..all about tuning to the pipe...
..but keep in mind, that once you install a 1500 contra, which s9lc scoots just seem to lloovvee, you probably going to need to stiffen the fly springs, in order to take full effect of the increased tension ...
..people keep shouting heavier rollers..it's never worked in my scoot, and nina jumps to 9000 and hovers there till i start to approach 55mph..
..now, she does have a pipe and filter, buti still remember 8200+ being a strong powerband when she was oem...
..get you some 9.5 and some 7.5 and give them both a try..i'll buy the 9.5s if you find you dont need them..
                                            ;D
Peters
  • In Glock I Trust
« Reply #21 on: August 23, 2012, 02:29:02 AM »
Compare the new belt to the old belt next time your in there. The size indicated on aftermarket belts is not always correct.
*2001 ZX-50 beater
Rage
« Reply #22 on: August 23, 2012, 02:42:43 AM »
Thanks for the quick replies. The belts are identical model #.  Other than the original being worn.,I did not try the 1500 spring without that yellow cap yet tho. I will try that soon also.
Rage
« Reply #23 on: August 23, 2012, 02:44:15 AM »
Just read again what u wrote. Will hold both belts together next time I crack her open. I did check that they were the same width.... The old one being about 2mm less wide, from being worn.
« Reply #24 on: August 23, 2012, 02:49:01 AM »
Just run the magic marker test to see. Did you keep the OEM sleeve inside the spring? I had to cut mine shorter using the Malossi torsion control.
Rage
« Reply #25 on: August 23, 2012, 02:50:50 AM »
I didn't cut anything..... Would I hear a scraping? How do I know if I need to cut it? By the marker test?
« Reply #26 on: August 23, 2012, 02:51:30 AM »
..yeah, do the 1500 WITHOUT the malossi yellow thingy...
..that yellow thingy probably takes that up to a 1600-1650...
« Reply #27 on: August 23, 2012, 02:52:45 AM »
..oem engine/intake/pipe will struggle to get there..
« Reply #28 on: August 23, 2012, 02:53:33 AM »
Yes. The sleeve will bottom out if it is installed with the torsion controller, blocking the td from opening all the way. Marker will tell you.
Rage
« Reply #29 on: August 23, 2012, 02:56:28 AM »
Cool, lots to test out. Just marked pulleys and going for a long drive tomorrow. Will see what happens. Then will try naraku 1500 spring by itself after. Thanks guys, will let u know how it goes.
