Author Topic: My TankGirl inspired Kymco Cobra 50cc ;D  (Read 4443 times)
Peters
  • In Glock I Trust
Re: My TankGirl inspired Kymco Cobra 50cc ;D
« Reply #15 on: August 24, 2012, 04:56:50 AM »
Changing the boss is not a big deal at all. Hardest part is getting the variator nut off. You need an impact wrench or something to hold the variator while you loosen the nut. Once you get that off it's really easy. Look up scooter CVT on youtube or google. You'll learn a lot about how they work.
*2001 ZX-50 beater
tankboyben
« Reply #16 on: August 24, 2012, 10:42:21 AM »
@ wordslinger, yeah in the UK, not sure of the laws your side, i think its restricted in the uk because 17yr olds arnt allowed to ride more than 50cc but im deffinitly not 17 anymore, so it needs to be de-restricted
@peters, thanks but im not sure you read my actual issue, ive seen many vids on how to change the boss, that all looks easy and straight forward, the issue im having is removing the crank case cover to get to it, for some reason it doesnt want to come off!
ce
« Reply #17 on: August 24, 2012, 01:30:26 PM »
Pound on it with a big rubber mallet, when it loosens up you'll hear it.
If it doesn't loosen, look around for the last bolt you forgot to take off.
Dead blow hammer.
Albuquerque, New Mexico
tankboyben
Re: Re: My TankGirl inspired Kymco Cobra 50cc ;D
« Reply #18 on: August 24, 2012, 01:36:51 PM »
Already did both. Attacked it like a loon with a mallet and checked every possible screw was removed. No joy.
Looks like ill have to take it to the garage. Cheers anyhoo peeps :-\
Peters
  • In Glock I Trust
« Reply #19 on: August 24, 2012, 02:50:47 PM »
I see
I didn't understand because you called it a crankcase cover
It's called the CVT cover
*2001 ZX-50 beater
tankboyben
« Reply #20 on: August 24, 2012, 04:50:48 PM »
Ah right. My bad. New to mopeds
« Reply #21 on: August 24, 2012, 06:29:15 PM »
Try wedging a putty knife into the crack. There are two locater dowels inside the cover that do get stuck. The cover is NOT water tight so no worries on making a dent in the seal/case.
« Reply #22 on: August 25, 2012, 12:51:53 AM »
..yeah, keep working at it..you'll get it...   8)
..be sure to clean and apply some dry lubricant to those dowels after you get it open..lol..
..they are scooters...NOT mopeds...lol..
                          ;D
« Last Edit: August 25, 2012, 01:23:14 AM by wordslinger »
« Reply #23 on: August 25, 2012, 03:28:31 AM »
tie a dog to the cover and let a cat loose... dog will chase cat... and...
Peters
  • In Glock I Trust
« Reply #24 on: August 25, 2012, 03:29:29 AM »
 :D :D :D
I like that idea  ;D
*2001 ZX-50 beater
« Reply #25 on: August 25, 2012, 05:00:08 AM »
That's how you pull teeth. Gators are for removing stubborn cvt covers
« Reply #26 on: August 25, 2012, 05:01:04 AM »
Forgot to mention... Leave the dog tied to the cover, and let the gator loose
« Reply #27 on: August 25, 2012, 05:21:05 AM »
