Author Topic: NEED CARB HELP!!!!!  (Read 5552 times)
Re: NEED CARB HELP!!!!!
« Reply #15 on: August 27, 2012, 09:24:42 PM »
..even a .0435" will be a 1.11mm if hand drilled...
..or a '111'..
« Reply #16 on: August 27, 2012, 09:27:58 PM »
..probably had to run the idle mix screw way in to get it to idle...
..i'm just sayin...
..probably need no larger than a .037" drill bit...
Scooter Russ
« Reply #17 on: August 27, 2012, 09:33:25 PM »
Ok I'll pick up so new jet & go from there......
Drive it like you stole it! Lol......
« Reply #18 on: August 27, 2012, 09:34:21 PM »
..if you have a smaller drill, saay a .038 you can solder that jet, then re-drill...
« Last Edit: August 27, 2012, 09:36:31 PM by wordslinger »
Scooter Russ
« Reply #19 on: August 27, 2012, 09:49:37 PM »
Ok just took scoot for a quick ride to run a delivery to a customer. At WOT I can hear carb spitting back thru air cleaner. So jet must be to big!
« Reply #20 on: August 27, 2012, 09:57:30 PM »
..that's exactly right...
Scooter Russ
« Reply #21 on: August 27, 2012, 10:01:03 PM »
No I've done screwed up one jet I'm not gonna try to resolder it & then redrill it. I'll just pick up a few larger jets & take it from there.
« Reply #22 on: August 27, 2012, 10:04:29 PM »
..gotta be careful not to get solder on the threads...lol..i did that a cpl times...
..recovered from it once, second time was a hot mess!!
Scooter Russ
« Reply #23 on: August 27, 2012, 10:08:36 PM »
Well wordslinger I can solder like nobodies business. sh** man I can solder the old brass fuel tank floats back together when they crack & start leaking. So I may take a crack at this then.
« Reply #24 on: August 27, 2012, 10:09:32 PM »
..it's either solder and dril...
..or order and wait.....and wait.......
« Reply #25 on: August 27, 2012, 10:14:17 PM »
..i just put the jet, threads up, on a hotplate....
..get the element good and red...
..touch the solder to the inside of the jet..cpl times...
..lift it off the plate with a pair of insulated needle nose...
..douse it with a lil water....
..sometimes i tap the jet on the element to assure the solder has went thru..
..some solder primer assists, but isn't a requirement...
« Reply #26 on: August 27, 2012, 10:19:15 PM »
..oh, i failed to mention that this takes a fairly steady hand, ssso...
..a cpl 24s are helpful in preparation for this task...
                            ;D
Scooter Russ
« Reply #27 on: August 27, 2012, 10:48:38 PM »
LOL!!! Like your prep method..... I'll be sure to do a couple of 12oz. curls before I start.
« Reply #28 on: August 27, 2012, 11:41:19 PM »
..well then you are well on your way russ!!
thebatman
« Reply #29 on: August 28, 2012, 01:14:38 AM »
I was scared to death of the thought of drilling out jets myself.
Just jump right on in there. It's not that bad. Dam sure beats....waiting....and waiting....
BTW, And HELL YES, that jet would be nasty big...
I was running a "90" in mine, now she is at a "87-8"?
I tried going the size of words and that was not working.....lol
"THE BAT"MAN...
Says:
