Author Topic: Battery change  (Read 2624 times)
Battery change
« on: August 27, 2012, 06:44:22 PM »
Original battery finally puked. Kept gettin' a 6 code on the CELP light. Got a replacement from Wal-Mart ( y'all just hush!) and followed the instructions exactly which includes 1-3 hour charge at less than 2 amps. I think this initial charge is important or the manufacturer would not insist. This initial charge is something that has been around for as long as dry charged batteries but most do not do it. Dealers do not generally do it because they do not want to take the time. I do not believe MY dealer did the initial charge because he did not even install the battery clamp! I have stated here previously this shortcoming. Now I am accusing him of not properly preparing the battery. I say this because I noticed a difference in how the digital speedometer behaves since the new battery is in place. It still seems to anticipate gaining and losing speed with a change in displayed numbers but does so in a smoother manner. It seems more stable in its presentation. Before it would dither all over the place especially at higher speeds (45 and up). All else seems the same.
Re: Battery change
« Reply #1 on: August 28, 2012, 03:33:39 AM »
ScooterWolf
Re: Battery change
« Reply #2 on: August 29, 2012, 12:54:07 AM »
My battery just died on Sunday, and my dealer has ordered a new one -- should be in on Wednesday. Glad I saw this post as I'll make sure that they charge it before I pick it up.
-Wolf
Re: Battery change
« Reply #3 on: August 29, 2012, 10:07:11 PM »
Yeah, Wolf. It will probably extend its useful life if they do as long as they don't go above 2 amps. Now maybe you can tell me what Vivo is snickering about......
Re: Battery change
« Reply #4 on: August 30, 2012, 02:43:28 AM »
ScooterWolf
Re: Battery change
« Reply #5 on: August 30, 2012, 06:15:40 PM »
He gets giggly whenever someone uses the word dither. That, plus he's crazy.
-Woif
Re: Battery change
« Reply #6 on: August 30, 2012, 06:35:24 PM »
Nyuk, nyuk! Must be the humidity and San Miguel in the PI!
Re: Battery change
« Reply #7 on: August 31, 2012, 06:30:41 AM »
I don't drink San Miguel...I drink Tanduay rum....
fshfindr
Re: Battery change
« Reply #8 on: September 01, 2012, 12:05:52 AM »
Ugg.  If you're gonna drink Tanquray, do gin.  Or is there really a Tanduay?
Richard L.
ps; I had to tighten down my battery connections again.  This time a wrench, no screwdriver.  :'(
Richard L. in Bellmawr
Re: Battery change
« Reply #9 on: September 01, 2012, 02:02:45 AM »
Richard L.
Here's my Tanduay Rhum!!  ;D ;D ;D
Tanduay 5-year old on the dispenser
Tanduay 12-year old in the cupboard...
« Last Edit: September 01, 2012, 02:04:31 AM by Vivo »
fshfindr
Re: Battery change
« Reply #10 on: September 02, 2012, 08:17:44 PM »
Oops, :-[  :-[  :-[  :-X  :-X   :)
Richard L.
« Last Edit: September 02, 2012, 08:19:21 PM by fshfindr »
Re: Battery change
« Reply #11 on: September 02, 2012, 08:54:19 PM »
Looks like Vivo got his booze set up like an IV bottle!
New battery DID NOT eliminate the low battery code (6). Went through the Service Manual procedure for that code and even applied dielectric grease on all connectors and I still got a code after a ride. All battery functions nominal: starting, lights, instruments. Battery volts consistent throughout albeit a bit low after surface charge goes away (12.86-12.95) . You tell me if you have any ideas. I plan to erase the code every time it shows up and keep on ridin'!
Re: Battery change
« Reply #12 on: September 03, 2012, 02:02:23 AM »
 8) 8) 8)
Covelivn
Re: Battery change
« Reply #13 on: October 03, 2012, 11:37:42 AM »
My two cents.
Please spend the few dollars and buy a Battery Tender from amazon and put that charger on once a week.
Two things you will learn to be aware of. 1 is my battery getting weak or dying and 2. Is my charging system working.
Years ago when Honda decided to sell cars in the US that had air cooled motorcycle engines, I had one and a dry battery exploded on me and I learned to respect the damage that can be done by a bad battery. Loved that Car.
Sincerely,
Cove
I wasn't born in Florida but I got here as soon as I could.
Re: Battery change
« Reply #14 on: October 04, 2012, 01:55:27 AM »
My two cents.
Sincerely,
Cove
Was that the Honda 600?
