Author Topic: Belt dressing  (Read 2382 times)
Belt dressing
« on: September 02, 2012, 02:26:47 AM »
Has anyone ever used belt dressing on there scoot.
and is it worth it.
streido
Re: Belt dressing
« Reply #1 on: September 02, 2012, 11:13:49 AM »
Yes, and NOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!! NEVER USE IT.  :o :o :o :o :o
Its designed for fixed drive belts NOT a moving and sliding CVT set-up.
I got some off an engineer at work who said it may work good and stop belt slippage. It did, my belt didnt slip at all, gearing didnt work, ran like crapcand i spent ages washing it all out my CVT. Its just for motorised belts than run between two fixed drives that dont move, like old pedastal drills, fan motors etc. NEVER USE IT ON A SCOOT. EVER.
Chaos is my co-pilot.
Re: Belt dressing
« Reply #2 on: September 02, 2012, 11:18:37 AM »
good to know thanks.........
griffon_j9
Re: Belt dressing
« Reply #3 on: September 02, 2012, 02:17:55 PM »
I prefer mine with a little Thousand Island, goes down easier.  ::) :D
honestly you should never use it on any belts, just gums things ups and can ruin things if used often
2010 Red Xciting 500RI  51 MPG so far
Re: Belt dressing
« Reply #4 on: September 02, 2012, 07:58:26 PM »
Belt dressing for any "V" drive fixed or not is a TERRIBLE IDEA!! The stuff was invented to "save" replacing worn-out "pulleys" which are properly called "sheaves" in the industrial power transmission field. Its use tends to increase the heat generated by the drive while in operation and reduce the power and torque output of the drive because the belt has to be "peeled off " each sheave. CVT heat does NOT need to be increased for any reason. And like Steido said it pretty much stuck his in one spot. Additionally, the sticky stuff usually attracts fuzzy stuff which makes the drive slip. You otta see the mess in a textile factory when one of the dummmies in maintenance uses belt dressing. Can you say, "Tar and Feathered?"
Re: Belt dressing
« Reply #5 on: September 02, 2012, 09:40:15 PM »
the can is in the trash..................o wait maybe ill spray it on my neighbors mail box.........
streido
Re: Belt dressing
« Reply #6 on: September 02, 2012, 10:23:39 PM »
Spray it on your hands and feet and see if you can Spiderman up the side of the house Blue  :D
Re: Belt dressing
« Reply #7 on: September 03, 2012, 01:55:09 AM »
We used it in our sewing thread rewinding machines in a factory where i was once. The machines have very long v-belts and required belt dressings.
Re: Belt dressing
« Reply #8 on: September 03, 2012, 08:15:55 PM »
Now I know what they use in the football games....They can suck that pig skin right in .........
skippy
Re: Belt dressing
« Reply #9 on: September 03, 2012, 08:51:46 PM »
never heard of this belt dressing but it sounds pants.
 dont the usa have an old trick called rescue tape, that is like the new wonder product. (silicon tape) that can be rapped round anything? belts, hoses, pipes etc. would have though it may have high friction though.
Oldie
Re: Belt dressing
« Reply #10 on: September 03, 2012, 09:44:49 PM »
We do have "Rescue Tape" in the USA.  In a couple versions!
Thanks,  ED
Silver Bullet- 2011 Downtown 300i
Re: Belt dressing
« Reply #11 on: September 03, 2012, 10:29:58 PM »
LOL ya I CALL IT DUCK tape..........
Re: Belt dressing
« Reply #12 on: September 04, 2012, 01:39:07 AM »
DUCT tape...
Re: Belt dressing
« Reply #13 on: September 04, 2012, 07:07:59 PM »
Quack! AFLAC!
Re: Belt dressing
« Reply #14 on: September 05, 2012, 01:37:27 AM »
