Author Topic: Stuck Variator Nut - Help Please  (Read 5725 times)
Pimpy1
  • Mo Hoes Power
« on: September 03, 2012, 08:36:06 PM »
Can't get the 17mm nut loose. Left liquid wrench on it overnight. Used an air then an electric impact wrench while holding the var still with tool. later heated the nut with a torch. Still no luck. Cracked off one of the two holes that you put the var holding tool in.  Not sure what to do next. Any tips?
2006 People 250
2011 Kymco Super 8 2t
2006 Kymco People 250
skippy
Re: Stuck Variator Nut - Help Please
« Reply #1 on: September 03, 2012, 08:42:42 PM »
would try heat again,then a spanner wedged in the case and the variator to stop it turning, then a big bar on the nut
Pimpy1
  • Mo Hoes Power
« Reply #2 on: September 03, 2012, 08:50:10 PM »
The nut is so tight I think I would bust the case if I tried that.  Going to keep soaking the nut with anti-seize fluid over night and will try more heat again tomorrow. Thanks.
skippy
« Reply #3 on: September 03, 2012, 08:54:13 PM »
love the dog pick though always makes me laugh. just cant believe what a tit the bloke was you took it from.
streido
« Reply #4 on: September 03, 2012, 10:13:50 PM »
Sometimes if you try to tighen stuck nuts etc instead of loosen them it can free it. Worked for me in the past on other stuck things. Then again it could just make it tighter. I would leave it to soak overnight in a good penetrating fluid, Plusgas works well for me, not sure if you can get it over there tho.
If it comes to it you might need to get a dremmel or hacksaw and cut it off and just fit a new one. If you can cut it near to tbe crank as poss and then chisel it to split it then it should come off without damaging the crank threads.
« Last Edit: September 03, 2012, 10:53:54 PM by streido »
Chaos is my co-pilot.
streido
« Reply #5 on: September 03, 2012, 10:26:26 PM »
What'd i miss? Someone been messing with the Pimpster?  :D
Pimpy1
  • Mo Hoes Power
« Reply #6 on: September 03, 2012, 11:16:33 PM »
See this thread for info. http://www.kymcoforum.com/index.php?topic=7499.0
Thanks for tring to help guys. Never see PlusGass before. I usually have to use MinusGas.
de-dee
« Reply #7 on: September 04, 2012, 05:55:51 AM »
I had the same problem with my dt. 300i I soaked it over nite with WD 40 applyed lots of heat, and used a large impack tool, I did not hold var.as it would break something I thought,.it worked! best of luck with your bike, de dee
« Reply #8 on: September 04, 2012, 06:05:40 AM »
You are being cursed by the dog owner.... apply some curse breaker oil or remove the pimp hat...
streido
« Reply #9 on: September 04, 2012, 07:28:09 AM »
Quote
Man some folk are tooooo sensitive lol.............  ::)
« Reply #10 on: September 04, 2012, 07:37:29 AM »
He took my dawg!...
skippy
« Reply #11 on: September 04, 2012, 08:25:40 AM »
there there vivo. its ok. bad man gone now.
Cortez
    • My flickr account
« Reply #12 on: September 04, 2012, 09:29:04 AM »
 ;D
'08 FZ6n S2 ABS
Peters
  • In Glock I Trust
« Reply #13 on: September 04, 2012, 10:49:07 PM »
No no no no no
You will crack the case
*2001 ZX-50 beater
Hoolander2
« Reply #14 on: September 05, 2012, 01:51:10 AM »
Maybe this'll help -- it's how I do mine.  http://www.kymcoforum.com/index.php?topic=3814.0
