Author Topic: kymco agility 125 stalling out problems  (Read 2276 times)
rodplatt
« on: September 05, 2012, 09:54:27 AM »
My kymco agility 125 keeps stalling out.  I believe gas is splashing up to the neck of the gas tank and getting into the evaporative emission control system and causing this.  Have you heard of this isuue and do you know of a solution?
Re: kymco agility 125 stalling out problems
« Reply #1 on: September 05, 2012, 12:06:07 PM »
if gas can splash out then you need a new gas cap. or check the seal on the cap.
untell then dont fell the tank so full..
whiteknight
  • ..Knight Tweed..
« Reply #2 on: September 05, 2012, 12:48:10 PM »
i have a 72cc agility and i fill her up to the brim without ill affect, no stalling or any other problems. when mine went through a stage of stalling i found out it the valves were too tight. do you have any other problems for example..running rough, sluggishness and general all round crappery? you might also want to have a look into your cvt give it a good clean out and general check up (if it needs it)
oh and before i forget...compression test the B*tch lol
streido
« Reply #3 on: September 05, 2012, 04:07:42 PM »
How is it stalling out? At idle when stopped or while riding?
Take it you adjusted the idle speed if its cutting out when idling?
Chaos is my co-pilot.
« Reply #4 on: September 05, 2012, 09:26:26 PM »
Lol I like that one.............
rodplatt
« Reply #5 on: September 09, 2012, 11:43:19 AM »
It stalls out when riding.  Every time I fill up.  Stops after a couple of days when tank is less full.
streido
« Reply #6 on: September 10, 2012, 12:06:50 AM »
Sound like you have the problem then in your 1st post. Sorry tho i have no experience of this on my A50 so cant help  :(
