Author Topic: Fed up with high rpm.  (Read 5455 times)
LoveMyKymco
Re: Fed up with high rpm.
« Reply #15 on: September 13, 2012, 02:54:27 PM »
Id just assume someone who rode and worked on their own motorcycle at age 5 would understand the concept of tolerances, especially a "race seasoned" master tuner. I personally dont think luck has anything to do with logistics, if theres 2 forces squeezing apart the same amount of force over a given predetermined length, theres going to be heat and eventually a bind or break. Something has to give. Sissy is trying to teach you something but you dont want to hear it.
Spindrift
Re: Sv: Fed up with high rpm.
« Reply #16 on: September 13, 2012, 08:44:32 PM »
Do undetstand fully and have been working on several scooters for years and never had any problem, that's all.
LoveMyKymco
« Reply #17 on: September 13, 2012, 10:20:51 PM »
Ill definitely say these engines seem to like higher rpms with out provocation. My friends 500 changes with the weather it seems.
sissy mary
« Reply #18 on: September 14, 2012, 03:46:11 PM »
Thank you LoveMyKymco. Changing weights are one thing, but changing the size of a roller will probably distroy the belt, if not the variator. :-*
Spindrift
« Reply #19 on: September 14, 2012, 09:15:07 PM »
Hmmm. Checked with one dealer and they say 2007- uses the same variator, same number.. can anyone confirm that?
sissy mary
« Reply #20 on: September 17, 2012, 12:05:57 PM »
Maybe so? Why build a new variator when all you need to do is go from 30 to 33 grams in roller weight to lower the RPM's somewhat because the fuel injected bikes have more power and torque? I have a 2007 with a Leo Vinci exhaust. I want to put in a DNA (K&N style) filter, and re-jet from the 118 to a 120 or 122. If this gives more power, I may experiment with heavier rollers to lower the freeway RPM's. I don't know if it could take the 33 gram weights or not? But 31 or maybe 32 may do the trick? Has anyone done this? :-*
Cortez
    • My flickr account
« Reply #21 on: September 17, 2012, 04:41:09 PM »
Dr Pulley.. damnit.
'08 FZ6n S2 ABS
Spindrift
« Reply #22 on: September 18, 2012, 10:09:29 AM »
Nothing wrong with stock vario. Just like to test different ones. I'm gonna test 32-33g with stock variator and harder contra spring . Also little bigger jet.
Cortez
    • My flickr account
« Reply #23 on: September 18, 2012, 02:31:55 PM »
I meant Dr Pulley sliders, not their vario.
Also, harder contra spring = higher revs.
Dr Pulleys will bring the revs down at cruising speeds.
'08 FZ6n S2 ABS
sissy mary
« Reply #24 on: September 18, 2012, 07:32:01 PM »
Cortez is right. Don't mess with the spring. Adjust your RPM's by way of the roller weights. I used Dr P 31 gram sliders in the bike once. At 1 gram over the stock weight of 30, it did lowwer my RPM's by about 500, I would say at freeway speeds. :-*
LoveMyKymco
« Reply #25 on: September 18, 2012, 09:02:40 PM »
harder contra = more force trying to downshift and stay in 1st/high gear.
Spindrift
« Reply #26 on: September 19, 2012, 11:57:30 AM »
Yes true but with heavier rollers you may need harder contra spring for balance. Sometimes just heavier rollers make the bike sluggish.
Spindrift
« Reply #27 on: September 19, 2012, 12:07:06 PM »
Everyone has to test different setups to find the one that suits their driving style. One other thing that I wonder about. Why are Dr. Pulley so popular in USA and not that popular in lets say Europe?
sissy mary
« Reply #28 on: September 19, 2012, 03:23:06 PM »
Maybe they don't market them there very well? I would not put in a stronger spring. If you go up in roller weight and then a stronger spring, you may just counter balance the roller weights. 31 gram (one G over stock) is a small amout to start with, and will not effect the power very much, so maybe start with 32 G and see how it go's? 33 G may be to much? :-*
Spindrift
Re: Sv: Re: Fed up with high rpm.
« Reply #29 on: September 19, 2012, 03:59:37 PM »
That is what I'm thinking too. On my Nexus I had Polini variator, +2g, kevlar belt and slightly harder contra spring. That was a perfect combo on that bike. Better acc., more responsive at all speeds and 700rpm lower at highway cruise. Did some testing with Malossi and J. Costa too.
