Author Topic: Valve adjustment on Peoples 200s  (Read 1427 times)
08087
  • 09' Peoples 200, NJ
« on: September 14, 2012, 06:51:46 PM »
My peoples 200s is overdue for a valve adjustment, what special tools will I need for this task and is there a tech bullitin someone can supply so I know what they should be set at?
Thanks in advance,
08
streido
Re: Valve adjustment on Peoples 200s
« Reply #1 on: September 14, 2012, 07:41:49 PM »
Thanks in advance,
08
Prob need a large flathead screwdriver and/or allen keys, feeler gauges and spanners. There will be a manual you can download here if you do a search, theres a thread somewhere with loads of manuals somewhere. That'll give you the valve gap setting.
This vid show generally how to do it.....
Chaos is my co-pilot.
08087
« Reply #2 on: September 15, 2012, 11:23:36 PM »
Thanks will do the search and get back if I come up short.
08
old geezer
« Reply #3 on: September 16, 2012, 01:01:52 AM »
I believe they set on .004 for both exhaust and intake.
08087
« Reply #4 on: September 16, 2012, 07:48:05 PM »
Thank you, I did a search and came away with .004 myself.
