Author Topic: Slight hesitation  (Read 1436 times)
mrmike
  • Syuracuse, NY
Slight hesitation
« on: September 15, 2012, 11:05:06 AM »
I have a People 150. The carb, jetting and airbox are all stock. The ignition is stock except for a iridium spark plug. I have installed a NHRC exhaust system, a 1500rpm contra spring, and replaced the stock 15gram rollers with 13gram rollers. The scooter takes off great, then has a slight hesitation, then picks up again right up throught the power band. Top speed is a GPS verified 60mph. Scooter runs and starts great other than that hesitation. I believe the hesitation was there when new, but seems more pronounced with the mods I've made. Any suggestions?
swiftscoot
Re: Slight hesitation
« Reply #1 on: September 22, 2012, 09:02:37 PM »
What happens when you're in the mid powerband and you pull full throttle?
mrmike
  • Syuracuse, NY
« Reply #2 on: September 27, 2012, 04:20:46 PM »
Power is smooth and steady if applied at mid range. Only notice hesitation when going from lower speed or start
swiftscoot
« Reply #3 on: September 30, 2012, 06:02:25 AM »
Sounds like your idle jet might be too small.
