Author Topic: Won't Start... Weird Noise  (Read 6207 times)
bootscooterboogie
Re: Won't Start... Weird Noise
« Reply #15 on: September 24, 2012, 07:21:39 AM »
The tire wasn't sticking out so far...
 ;D
2009 Kymco Agility - 50cc
1999 Yamaha Zuma - 50cc (sold but not forgotten)
"If stupid people were trees...  I'd be living in the enchanted forest..."
mono
« Reply #16 on: September 24, 2012, 12:09:08 PM »
I once knew some bikers from the "Asshole" category, who tried to justify their excessive speeding by keeping up the myth that motorcyclists are only a danger to themselves.
I wish I had this picture back then, it would have quickly ended those discussions...
bootscooterboogie
« Reply #17 on: September 25, 2012, 02:40:20 AM »
Quick update - with the new battery charged, it tried to turn over but no luck.  So...  work continues on it tomorrow.
« Reply #18 on: September 25, 2012, 03:11:57 AM »
Do you have the rubber seal on the cvt cover. if not put it back on I had the same problem befor
and found out it was only the cvt cover seal was off,For some reason the agiltys wont start unless its on. if you dont have one put a rubber washer on the bolds .I think the cover needs a seal of some typ because the starter ground wire is just so close to it and it inter fears with starting.
bootscooterboogie
« Reply #19 on: September 25, 2012, 03:30:07 AM »
Right on - I'll double check tomorrow.  That would def be something I would overlook.  hehehe
« Reply #20 on: September 25, 2012, 03:31:57 AM »
A good tip from Blue... ;)
