Author Topic: Derestrict Kymco MXU 50  (Read 4931 times)
tavib
« on: June 10, 2009, 11:57:25 AM »
 Hi , for more speed and power I know about 70cc Malossi .
 Do you know other derestrict methods ? Cdi ? Exhausted ? ...
 Now it runs 40Km/h , hope about 50 maybe more ...
Thank you !
Re: Derestrict Kymco MXU 50
« Reply #1 on: July 15, 2009, 12:08:07 AM »
..engine tuning and preventive maintenance is first...I have an Agility 50, so I also must keep my valves adjusted...but, start with the basic mechanical needs first...In my experience, a balance of torque and speed is what we're looking for on our 50 (49) cc scooters..if your engine is performing like it SHOULD be, start with any known "de-restricting" methods that are specific to you scoot.....A variator upgrade might cost you around $100.00, and make world of difference in it's performance...
axy
« Reply #2 on: July 15, 2009, 09:35:07 AM »
MXU is a quad, not a scoot.
One question, you are mentioning valves. Once I spoke with a mechanic who performed maintenance on my Piaggio Beverly 200 and he said that even after 20.000 kms, the valves do not get misaligned. Did you notice that valves on Agility 4 stroke really have to be adjusted so often - every 3000 kms according to the user's manual? Tnx.
Kymco Agility 125 2008
« Reply #3 on: July 15, 2009, 09:16:50 PM »
..damn..how th hell did I get in here...
..sorry, dudes...wrong board..
yeah, man.....I guess I'm not really talking about a mis-alignment, rather a normal wear of the cam lobe, rocker arm and valve stem, valve seat, valve springs.....Over time, normal wear on mechanical parts that "strike" each other is going to occur...even though, most of these are continuously lubricated....
..on the agility 50, the valve clearance is .04mm...this gap ensures that the valves get opened at the optimum distance... this unsures that the maximum amount of fuel mixture enters the cylinder..as well as allowing ALL the combusted vapors to be completely exhausted..
..I've adjusted mine 5 times..and each time, the gap was greater than spec..
« Last Edit: July 15, 2009, 09:19:21 PM by wordslinger »
axy
« Reply #4 on: July 16, 2009, 09:11:06 AM »
The last sentence is most important for me, tnx. So, it does make sense to make that kind of inspection.
The problem is that looking at pictures, adjusting valves looks like helluva job to me... and I am not sure I would not break something doing that...
