Author Topic: battery  (Read 1247 times)
battery
« on: September 18, 2012, 08:48:19 PM »
I have a 7 amp battery I just put in my chinnese scoot and dam she fires up in no time.
Is it save to use that big of a battery in the kymco scoot.
MaryK
Re: battery
« Reply #1 on: September 19, 2012, 12:59:41 AM »
If it fits in the battery case and is for 12 volts, then it should be ok.
Is it maintenance free or does it use electrolyte ?
Scoot safely,
New Rider in 2010
2009 GrandVista 250
Re: battery
« Reply #2 on: September 19, 2012, 02:13:43 AM »
Scoot safely,
yes to both......
Re: battery
« Reply #3 on: September 19, 2012, 05:18:15 AM »
I have a 7 amp but the 9 amp fits fine except a little bit taller. I'll get the 9 next time...
Re: battery
« Reply #4 on: September 19, 2012, 12:59:29 PM »
thanks I have been finding out that the batterys with more amp realy helps with the starting of the scoot.
REDKYMCO
Re: battery
« Reply #5 on: September 20, 2012, 10:25:14 AM »
I had a 7amp fitted by the dealer to my peugeot kisbee 50 gy6 that i owned last year as the 4 amp had no back bone and as you say it really helps with cranking power especialy a must in them minus temps in deep winter, when my agility battery starts to weaken i will be getting a 7amp, is your 7amp a gel battery i was told the one i had fitted was a gel battery they normaly fit to the honda cbr125 as that one was the only one they had in stock that would fit as it was only slightly larger.....
IF IT IS NOT BROKE DONT FIX IT:)
Re: battery
« Reply #6 on: September 20, 2012, 12:37:57 PM »
No not a gel battery just a bigger one .
