Author Topic: Pictures of my first oil change  (Read 4152 times)
Kenneth76
Re: Pictures of my first oil change
« Reply #15 on: September 22, 2012, 03:13:22 AM »
Teemon, I use an allen wrench to loosen the drain bolt, no torque wrench, but to loosen the oil filter cap, I Use a torque wrench, which must be used carefully, because if you squeeze it too can damage the thread or the filter plug. I recommend you use an allen wrench, but in my case I did not have one of that size and so Use a torque wrench carefully, that's it, is not difficult.
Kenneth76
« Reply #16 on: September 22, 2012, 03:27:52 AM »
MassScott, the reason why use synthetic oil, is because the manual says and recommended, I am sending this photo of the part where the manual says.
« Last Edit: September 22, 2012, 04:16:55 AM by Kenneth76 »
Kenneth76
« Reply #17 on: September 22, 2012, 03:44:38 AM »
But in the other manual I found online, says to use premium quality oil, but I follow the instructions of my original manual. Please see the attachment. ???
« Last Edit: September 22, 2012, 03:56:31 AM by Kenneth76 »
MassScoot
« Reply #18 on: September 22, 2012, 06:44:05 AM »
Ken: You'll be fine. Just @ 600 miles, the feel the engine still needs some more breaking-in yet. I would think most people would agree @ 1500+ miles is the best time to use synthetic oil. I have own 5 scooters (all brand new) & that's what I have done for all of them. Again...No worries. Nice job on the pics again!
Gloucester, MA. (Home of the Perfect Storm)
2012 Silver Kymco GT300i (Biondi Windshield/Shad SH40 Cargo Topcase)
2015 White Honda PCX150 (Shad SH37 Topcase)
2013 Yellow Lance PCH125 (Shad SH33 Topcase)
ProfessorDumbledore
« Reply #19 on: July 17, 2014, 12:38:39 AM »
How many cans of oil does your Kymco usually need?
agilebda
« Reply #20 on: July 17, 2014, 12:53:51 PM »
One US Quart should do it. After 3/4 of that quart is in the engine, use the dipstick to check the oil level and add oil accordingly. Usually should have a very little oil left in the bottle.
NeoGenesisMax
« Reply #21 on: July 17, 2014, 05:53:07 PM »
I dont see the second oil filter. Did you take it out and clean the metal shavings off it? You do know there are two right?  BTW the repair manual is sold by amazon for kindle. So if you have a smart phone you can have the manual on your phone.
agilebda
« Reply #22 on: July 18, 2014, 12:16:57 AM »
Second Filter? Where's that one located?
Trucker jay
« Reply #23 on: July 18, 2014, 01:22:22 AM »
You can download service manual thru kymco USA for free.   I sure I used a quart and then some when I serviced my scooter last Saturday.  The second oil filter is behind the other drain plug.  The drain plugs are beside each other.
NeoGenesisMax
« Reply #24 on: July 18, 2014, 04:41:53 AM »
There is a metal oil screen. And you are supposed to use a torque wrench for every thing. The service manual shows the screen to under the 17mm bolt next to the drain bolt. There is a washer there that needs to be inspected and replaced if needed. Use needle nose pliers to remove the strainer. It is a cylinder shape. It also has two o rings that need to be inspected and replaced if needed. Always lube them befor reinstall. It says to clean the screen with high flash point solvent and compressed air. The 17mm strainer cap gets torqued to 7.2 lb-ft on reinstall. Btw the oil filter cap is 7.2 as well. 5w-50 synthetic oil is suggested but 5w-40 will do ya fine.
