Author Topic: Crank case removal problems  (Read 1026 times)
A$APAgility
« on: September 20, 2012, 11:00:17 PM »
I'm have trouble removing the crankcase because there are 2 screws that are hidden behind the fairings what would you guys recommend doing?
skippy
Re: Crank case removal problems
« Reply #1 on: September 21, 2012, 07:48:11 AM »
are you removing the crank case or the cvt cover( to put in your new varaitor)?
if its the cvt cover then the bolts i think your talking about are
1 by the pasanger foot rest.( top left corner) - use a ratchet with a long exstention 8mm scocket.
2 will be behind the dranage hose between the cvt and air box( top middle) - pull the hose off or rotate the hose round out of your way. you should now have acsess.
streido
« Reply #2 on: September 21, 2012, 07:50:59 AM »
You can remove the 2 bolts that are kinda hidden, just reach a small spanner in there or use a small socket on an extension bar or T-bar, thats what i use, never had a problem removing mine.
......and Skippy just answered 1 sec before i posted and stole my thunder...
Chaos is my co-pilot.
skippy
« Reply #3 on: September 22, 2012, 07:45:52 AM »
 ;D
like i say to the missis. no prise for coming second.... ;D
hows the t5 clasic going streido?
streido
« Reply #4 on: September 22, 2012, 11:25:48 AM »
Quote
Mot'd, taxed and insured, been riding it to work since Tuesday. Still got a couple of small jobs to do and think i need to clean out tje carb again cos of crap in the tank. Plan on giving it a long run tomorrow.
skippy
« Reply #5 on: September 22, 2012, 05:09:35 PM »
 ;D just dont neglect the kymco. it may fall out with you if you dont pay any atention.
the t5 looks fantastic. wasent sure about the grey at first, but looks real deep shine. thats what was making me think about thoes ones at my shop for £500 that needed work. hope i do get the chance one day.
mono
« Reply #6 on: September 23, 2012, 06:51:12 PM »
My favorite tool for the CVT cover is an 8mm nut spinner, something like this :
http://nl.rs-online.com/web/p/nut-spinners-sets/4992335/
It even reaches those bolts behind the fairings since it's very thin and will also work under a slight angle without damaging anything...
