Author Topic: Need accurate belt size for People 150  (Read 2879 times)
John in PA
« on: September 21, 2012, 10:39:13 PM »
I want a kevlar belt for a 2009 People 150.  I just received a Gates belt from a scooter parts dealer.  Size WAY wrong! Apparently some (many?) of the aftermarket databases show incorrect info.(!!)   Original Kymco belt has no size numbers, only a Kymco part number.
 Does anyone know with certainty which size belt is correct for the People 150? I'd like a Malossi Kevlar if I can get the correct one.  Best info I can find says 795-19.8-30??
(cross-posted from the People 150 thread)
mrmike
  • Syuracuse, NY
Re: Need accurate belt size for People 150
« Reply #1 on: September 21, 2012, 11:38:27 PM »
John
Don't know if this helps any, but my 2010 people 150 belt says   Kymco 23100-KEC4-9000  Bando DBKYUECB. I looked awhile back and found this bando belt. Maybe you can cross reference it.
John in PA
« Reply #2 on: September 22, 2012, 02:03:33 PM »
thanks for the tip.  I'll see what I can find.
John in PA
« Reply #3 on: September 22, 2012, 06:33:54 PM »
No luck searching the letter designation.  Lots of Bando automotive belts, motorcycle superstore has a stock belt, and another brand, Erlandson, which is labeled Kevlar, which, at $35, is the cheapest Kevlar belt I've seen.  Anyone ever try that Erlandson  brand??
John in PA
« Reply #4 on: October 08, 2012, 10:48:20 AM »
OK.  I can verify that the Malossi Kevlar belt  sized 795-19.8-30 is a direct replacement for the factory belt in the People 150.  Also, the Dr Pulley variator for the GY6 150 works well.  With 13 gm sliders installed, I could notice a seat-of-the-pants improvement in take-off acceleration, but lost a couple mph maximum speed.  I put in a set of 15 gm sliders and I would say acceleration was similar to stock and that, in combination with the Malossi belt, I might have picked up 3-4 mph top end.
I would say that, so far, the performance gains over stock vs. time and money spent achieving them are not worth the money.  I think the 50cc scooters can be changed dramatically with modding, but the People 150 performance is apparently nearly optimized at the factory, at least with the stock carburetor.  Whether a larger intake manifold and a couple mm larger carb would change much is a question I don't think I'll bother to investigate.  And the CVT drive ratios with the 16" wheels don't allow sustained top speeds even on mild hills at WOT.
