Author Topic: Important things to do for a bike that has been sitting for a while?  (Read 1537 times)
tstalion79
Well I picked up my ZX50 the other day.  It is a 2000 model with just under 2,000 miles on the odometer, and has not seen much action at all for the past few years.
The engine seems to run well, but the belt snapped within the first 10 miles of riding it.  I took apart the transmission to find that the rollers had a bunch of flat spots, so I replaced that along with the variator (OEM).
What else should I check/replace?
PANCHOBARRONR
Re: Important things to do for a bike that has been sitting for a while?
« Reply #1 on: June 11, 2009, 04:37:15 PM »
CHANGE the cdi unit, spark plug, drain the gas put new gaS . CHECK oil levels
chubbyrockstar
« Reply #2 on: June 11, 2009, 06:09:16 PM »
I changed my CDI, Plug, Coil and gas also.
I pulled my gas tank off for further inspection due to a tad of flaky rust bein near the top of the tank. I wanted to make sure one of those particles was not going to clog my jets or filters.
tstalion79
« Reply #3 on: June 11, 2009, 06:39:36 PM »
Sounds good.  Where can I get a new CDI?
I also noticed a couple cracks in my tire right around the rim.  The tread is great, but I don't want a catastrophic blowout.  Is this OK?
chubbyrockstar
« Reply #4 on: June 11, 2009, 06:50:30 PM »
If you want an Original equipment cdi you can have your local motorcycle shop order it or you can call these guys if your in the U.S, I just posted something around here somewhere as far as the cost, i think it was around 50 bucks but thats pretty steep.
734-484-9993
Scoot Around Town
Ypsilanti Michigan
the 50cc one..i think http://kymcopartsonline.com
has them too
Heres the race one, But it requires re-wireing and splicing to fit the zx50
http://cgi.ebay.com/ebaymotors/RACE-CDI-50cc-Honda-dio-elite-Kymco-Sym-Pgo-Scooter_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1205Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem1e56ddae2cQQitemZ130306387500QQptZOtherQ5fVehicleQ5fParts
here read this first though
http://www.kymcoforum.com/index.php?topic=540.0
as far as the tire NO, any cracks can mean dryrot get a new tire/tyre the only thing between your life and the road is your tires.
( if they are very tiny you might get away with it for a few but it can be dangerous if they are deeper cracks than they appear.)
« Last Edit: June 11, 2009, 07:11:26 PM by chubbyrockstar »
