Author Topic: Trouble shoot engine sound - New video added  (Read 2972 times)
mmaxima
« on: September 23, 2012, 07:04:18 PM »
Update 11/06/12
I replaced the auto choke, bystarter and it fix the starting problem. The bike will start right up without throttle now.
Ever since I got my 2007 people s 250, I've been trying to identify the weird engine sound. I always need to give a little throttle to get it to start when the bike is cold. It will not idle stable. I've play with the idle screw, replaced the gas filter and spark plug. I also clean the carb. The battery is in good shape. The next thing I'm going to do is to replace the auto choke, bystarter. I've attached the video that has the engine sound. I was hoping someone can help me trouble the problem. Thanks.
New video added. Transmission case removed.
« Last Edit: November 07, 2012, 03:49:46 AM by mmaxima »
gregspeople250
Re: Trouble shoot engine sound
« Reply #1 on: September 24, 2012, 11:46:29 PM »
My People 250 idles much faster than that at cold start.  Hopefully, it's just a low idle or the bystarter has failed.
Honda Elite 80 - SOLD
Yamaha Vino 125 - SOLD
Kymco People 250 - SOLD
Kymco Like 200i - SOLD
Vespa 250 GTS - SOLD
Piaggio BV350 - FUN! - SOLD
Buddy 170i - FUN! - SOLD
Honda Silverwing - SOLD
Yamaha TMAX - OUTSTANDING! - SOLD
Honda SH150 - SOLD
Yamaha SMAX - SOLD
Kymco AK550
Pimpy1
  • Mo Hoes Power
« Reply #2 on: September 25, 2012, 12:33:37 AM »
That sounds like an exhaust leak. Also check for hole on vacuum hose coming off the top of the carb. Just under the seat bucket. It can get pinched there.
2011 Kymco Super 8 2t
2006 Kymco People 250
mmaxima
« Reply #3 on: October 04, 2012, 04:19:13 AM »
I've heard people saying it's possible the belt hitting the transmission casing. I'll open it up this weekend and find out if that's true. Some people has complain that one of the screw on the upper right corner of the casing is terrible hard to unscrew. I was able to use a 8 mm wrench to loose it and use my hand to remove it. Take me 10 minutes. And I don't have to remove the seat like others did.
gregspeople250
« Reply #4 on: October 04, 2012, 03:21:50 PM »
That's not the belt making the sound; it's the sound of a very low idle.
Have fun and be sure to use assembly lube on the fasteners when you reassemble and torque to spec's in manual.
Honda SH150 - SOLD
Yamaha SMAX - SOLD
Kymco AK550
Rudolf
  • Born to be wild!!!
    • Facebook
Re: Trouble shoot engine sound - New video added
« Reply #5 on: February 14, 2013, 09:35:52 AM »
I believe it's the timing chain rattling. The Grandvista (Grand Dink) and People 250 have the same type of engines. Mine had a worn timing chain and was flapping around inside the engine only at low RPM. I have a video with my bike running having the CVT removed and before changing the timing chain: and here is a video after i've changed the timing chain:
« Last Edit: February 14, 2013, 09:41:40 AM by Rudolf »
Rudolf
    • Facebook
« Reply #6 on: February 14, 2013, 09:40:42 AM »
Try running the engine with the CVT and belt removed and see how it sounds.
naughty lee
  • 64 mph and pushing
« Reply #7 on: April 09, 2013, 07:31:16 AM »
I'll go with that, put your hand in to where the exhaust mates against the engine ( with the engine running but not red hot) can you feel a draught of exhaust gas ?
I'd also increase the idle speed by a 1/4 of a turn
