Author Topic: dead  (Read 5342 times)
skippy
Re: dead
« Reply #45 on: October 27, 2012, 08:46:38 PM »
thanks mono. to be honest i never grese up the piston. i figur that the brake fluid does that job. but when i pumped the brake and pushed piston back a fue times to free and losen up i noticed a little corotion on the piston its self. like it was sticking. it does not pump out same as the other. so may be time to change. will strip it down again and grese up with silicon around piston see it its better first. thanks for agvice.
mono
Re: dead
« Reply #46 on: October 27, 2012, 09:10:11 PM »
I've had the same problem of light corrosion on one of the brake pistons with my 2006...
I didn't feel like taking it apart completely at the time, so I only took the caliper off the front fork with the hose still attached, took the brake pads out, and pumped the pistons out just as far as I thought to be possible without the bottom of the pistons passing the seals (and causing the system to empty itself all over the place  ;D)...
With the pistons extended as far as I dared to go, I polished the pistons by wrapping a shoestring around them and pulling it back and forth...(= the only way to get around the pistons without disassembling them completely)
This really did the trick, the pistons were smooth again, apart from a slight discolouration where the rust had been, did the same trick again with a clean shoestring soaked in silicone grease - and this caliper has been fine for two years since...
mono
Re: dead
« Reply #47 on: October 28, 2012, 08:01:32 AM »
Oh, and by the way : replace the brake fluid every year or so...
It attracts water, which causes most of this kind of corrosion...
skippy
Re: dead
« Reply #48 on: October 28, 2012, 04:49:14 PM »
 that  prob why. its prob never been changed. will have to look at that too.
