Author Topic: Tip -Tighten the Oil Filter Tighter than Normal  (Read 1333 times)
Oldscoot
« on: October 12, 2012, 07:53:01 PM »
My mechanic, who has been working on Kymcos for years, said that he tightens the oil filters on Kymco 500 bikes tighter than the normal "hand-tight" standard.  He said he's seen the filters on 500s work loose in the past.  Just passing it on.
fshfindr
Re: Tip -Tighten the Oil Filter Tighter than Normal
« Reply #1 on: October 13, 2012, 02:04:56 PM »
I use the torque wrench.  The recommended 8.6 ft/lbs is considerably more than hand tight.
Richard L.
Richard L. in Bellmawr
sissy mary
« Reply #2 on: October 13, 2012, 02:56:57 PM »
Just a little to tight and the threads will strip. Be careful. :-*
Oldscoot
« Reply #3 on: October 13, 2012, 05:19:43 PM »
Richard L.
Richard - which type/brand filter wrench do you use?
sissy mary
« Reply #4 on: October 14, 2012, 11:24:00 AM »
He is probably using the K & N 147 with the nut on the bottom? Thats what I use. :-*
fshfindr
« Reply #5 on: October 16, 2012, 03:28:10 PM »
I put a 17mm socket on my torque wrench & torque it to 18ft/lbs, not the afore mentioned 8.6ft/lbs which I must have mis-read from my list.  The 8.6ft/lbs is for the oil filter cap nut.  Now I have to go check it on the bike.  :-[
Richard L.
ps: It is a Craftsmen wrench
« Last Edit: October 16, 2012, 03:32:34 PM by fshfindr »
