Author Topic: Is this normal  (Read 1672 times)
mnpugdog
Is this normal
« on: October 16, 2012, 07:47:51 PM »
So I have been riding my 300 for about a month now. At lower speeds it hesitates like it's not getting enough gas. This is my first scooter with EFI, It only has 180 miles on it so far. Is this normal for the 300 until it breaks in or should I have a dealer look at it?
bdrannik
  • Southwest Florida USA
Re: Is this normal
« Reply #1 on: October 17, 2012, 12:51:14 AM »
Has it always been this way or something new?  In case it's a bad tank of fuel you might want to run this tank low and then refill it with fresh fuel.  If that is not the problem I would have the dealer take a look at it.
2011 DT300i - Givi Windshield - HID 5K Low/High Beams - LED Tail/Turn/License Bulbs - Front signal mirrors converted to running lights/signal - Dummy bulbs to LED 5K white running light/amber signals -  Givi E55 w/Admore LED Kit & custom paint - Scorpio SR-i900 Alarm - NGK CR7EIX - Amsoil Synthetics
Cortez
    • My flickr account
Re: Is this normal
« Reply #2 on: October 17, 2012, 03:31:30 PM »
If it's up to 20mph and at the clutch engaging revs (below 4000), then it's ok.
'08 FZ6n S2 ABS
mnpugdog
Re: Is this normal
« Reply #3 on: October 17, 2012, 05:52:07 PM »
I was thinking possibly bad gas from the dealer too.
It happens between about 15-40 mph, after that it might be happening but not sure.
jwalz1
Re: Is this normal
« Reply #4 on: October 17, 2012, 08:56:10 PM »
Mine has weird symptoms when the tank gets to about a half gallon from the vapor lock in the fuel tank.  If I take off the gas cap and it sucks in a bunch of air and then put the cap back on, it is fine.  Does not have a problem when full.
