Did you miss your
activation email
Scooters - 125 to 300
People 250
tail and brake light access for People 250
Topic: tail and brake light access for People 250 (Read 1000 times)
Ray
Newbie
October 26, 2012, 11:54:13 AM »
I recently got at 2006 People 250. I have a top case with brake and running light LEDs. Short of removing a lot of plastic, is there a way to access the needed wiring harness (maybe by removing the storage bin)? I really appreciate any ideas. Thanks.
Rudolf
Full Member
Born to be wild!!!
Re: tail and brake light access for People 250
February 14, 2013, 10:25:39 AM »
For my Grand Dink 250 I've had to remove the trunk and seat assembly to get to the rear light's wiring harness so i could connect my top case lights that I've had to make by myself. The top case didn't had any lights, only a red transparent plastic, so i've bought around 40 cm's of red light, self adhesive LED strip and placed them under the red plastic and connected them in parallel and the LED strip assembly connected them to the rear light wiring harness. I've also added a connector on the wiring to remove the top case more easily.
There are three strips: the center strip is the rear light and the upper and lower strips are for the breaking light.
DoubleSC
Newbie
February 15, 2013, 04:45:27 AM »
Just pull the seat/storage bin out and you can access the wires you need as they run back past the seat latch area. According to the schematics, you'll need to attach to these wires:
Green (solid): Ground
Green with Yellow stripe: Brake Light
Brown (solid): Tail Light
If you need more in the way of manuals or schematics, look here:
http://scootdawg.proboards.com/index.cgi?action=gotopost&board=200cc&thread=6804&post=65236
DSC
Back
