Author Topic: Torque speck on varaitor nut and clutch  (Read 911 times)
Bray0671
« on: October 28, 2012, 01:59:48 AM »
What do you guys torque  the varaitor and clutch nut.
mono
Re: Torque speck on varaitor nut and clutch
« Reply #1 on: October 28, 2012, 07:58:46 AM »
I tried the value that Kymco advises in the service manual, but I found it to be uncomfortably tight...
Since I do variator maintenance and tuning more often than Kymco had in mind when writing the manual - and stripping the threads off the crankshaft would mean a lot of work and quite a lot of money for a new crankshaft - I decided not to go with Kymco's specs.
I apply a thread locker (Loctite 243 retainer) to the nut, and tighten it only as much as I feel comfortable with - tight enough to keep the ramp plate from slipping, but not so tight that you can feel things bending or galling...
Never had a variator nut coming off - works for me, but YMMV of course... 8)
streido
« Reply #2 on: October 28, 2012, 12:17:14 PM »
+1 on the locktite, blue locktite works for me fine bu also used green in the past which is stronger but worked fine.
I used a impact wrench so usually give it about 4 bangs once it nips uo tight, never had an issue yet after its been on and too many times to count.
Def use locktite tho cos i had nuts come loose in the past  :o
Chaos is my co-pilot.
skippy
« Reply #3 on: October 28, 2012, 04:45:00 PM »
i had that problem once, dam thoes 80s speados swiming pants.
mono
« Reply #4 on: October 28, 2012, 05:34:32 PM »
 ;D ;D ;D ;D ;D ;D
