Author Topic: MXU 500 Charging issue  (Read 1679 times)
BG62
« on: October 30, 2012, 04:59:23 PM »
I have a 2008 MXU 500, I love it except I can't keep the battery charged.  Usually the machine stops at the worst time, like when I am halfway across my 40 acres.  I have replaced the battery and solenoid.  A little background, mice gnawed my wires under the seat last winter, I have replaced, spliced or sealed all areas where the mice got their little teeth into it.  most of the gnawing was just the insulation, not the wires, but I have had the charge problem since then.  Thanks in advance
BG
naughty lee
  • 64 mph and pushing
Re: MXU 500 Charging issue
« Reply #1 on: March 31, 2013, 07:36:16 PM »
A volt meter set to dc should be put onto the battery terminals. It should show 12-13.8vdc
With the engine running you should measure 14-14.5vdc
If you are seeing less than this, there is a fault on the stator, the voltage regulator/rectifier, the battery or the wiring between them.
That is all.
