Author Topic: Unleaded or Premium Petrol[SOLVED]  (Read 8333 times)
Re: Unleaded or Premium Petrol
« Reply #15 on: November 09, 2012, 02:00:15 AM »
Well gotta weigh in on this one, here is my spin on it,Premium fuel has no Ethanol and since scooters and small cc machines carry only small amount of fuel....I say go for the good stuff, here is why,I see lots of problems caused by Ethanol fuels, they are corrosive and go stale very quickly resulting in lots of "no starts" after sitting for a short period of time and damaged carb parts where fuel has been allowed to sit for several months. The small additional costs of the better quality fuel far out weigh the costs of service/repairs incurred with its use.
Enjoy the Ride !
From what country are you from?  Our gasoline here all have 10% ethanol... it's the law...
juice
« Reply #16 on: November 09, 2012, 03:22:39 AM »
Gas stations that sell non ethanol gas can be found at the puregas.org website . The stations are listed by state and then city . Good luck .
mono
« Reply #17 on: November 10, 2012, 08:05:38 PM »
+1 on the non-ethanol stuff... Ethanol is technically (still not politically) acceptable for modern car engines with a self learning engine management system and an ethanol resistant fuel system - not for simple carburetted scooters...
I'm not the only one who had (because of the slowly increasing percentage of ethanol in our fuel) issues with the mixture being lean because of the different oxygen needs for ethanol, and with plug chops not telling anything useful anymore when trying to compensate for this...
After switching to ethanol-free gasoline these issues vanished as expected....
In the Netherlands, at least the "Shell V-Power E95" brand is currently ethanol free (I test this regularly) and it's not that much more expensive compared to the regular ethanol contaminated crap...
« Last Edit: November 10, 2012, 08:09:53 PM by mono »
Zimmerman
  • Northeastern Pennsyvania USA
« Reply #18 on: November 10, 2012, 11:56:50 PM »
Mono,
How do you test to see if the gas is ethanol free ?
KZ
Kymco Yager GT200i
Kymco People 150
Yamaha Riva 125
Zimmerman
« Reply #19 on: November 11, 2012, 01:09:06 AM »
Here is a semi-related question for the group . . . at the cycle shop they sell an additive that is supposed to counter act the effects of Ethonol.
Do any of those products work ?
KZ
Kymco Yager GT200i
Kymco People 150
Yamaha Riva 125
old geezer
« Reply #20 on: November 11, 2012, 02:30:41 AM »
KZ
Gas pumps will have a sticker saying if they contain ethanol. Here they say up to 10% ethanol added.
Star Tron is good stuff. I get it at the scooter shop. The guys there use it. Also boat owners use it. One bottle will last a long time for scooter use. It says it will keep the fuel stable for up to two years.
http://mystarbrite.com/startron/
mono
« Reply #21 on: November 11, 2012, 12:20:49 PM »
Quote
Mono,
Put some water in a small glass jar, about 15% of its total volume. Precisely mark the level of the water on the outside of the jar. Fill the rest of the jar with gasoline, put the lid on, shake it to mix the water and gasoline, and put it down to rest. After a while the gasoline and water will be separated again. If there was any ethanol in the gasoline, most of it will have migrated to the water - so if the water level remained exactly the same, the gasoline is ethanol-free...
Quote
Ethanol has more than one side effect, and I can only imagine one of those (corrosion) to be countered by a small amount of some chemical compound... They cannot change the fact that ethanol contains an oxygen atom in every molecule while gasoline does not, for example, or that ethanol is a solvent which will penetrate some plastics and rubber...
I'm pretty sure that it won't prevent a carburetted engine from running lean, or plug chops from being way off, or prevent seals from swelling, or prevent composite fuel tanks from slowly solving, etc...
As long as they won't explain exactly what's in this stuff and why it should work, I consider this stuff to be a regular case of snake oil  ;D
Quote
Over here they don't...
(And since this industry is about making money, ethanol is heavily subsidized, and petrol companies don't have a track record for reliability, I wouldn't trust a sticker anyway...)
old geezer
« Reply #22 on: November 11, 2012, 02:15:16 PM »
kymcoholic
  • Kymco Parts shipped Worldwide !
    • KymcoGenuineParts.com
« Reply #23 on: November 28, 2012, 07:24:37 PM »
Hello...I am located in Hamilton, Ontario, Canada.
This link should help most people interested in this topic, its a list of Ethanol free stations both sides of the border as well as some interesting info.....for example no Ethanol in Alaska...hummm....most likely due to the cold start issues related to ethanol
http://pure-gas.org/
MotoRandy123
  • Lets Ride!
« Reply #24 on: November 28, 2012, 07:36:41 PM »
 My Yager says not to use ethanol fuel, but the only place I can get it is 50 miles north at a
marina. Startron is supposed to fix the ethanol so I use it but not sure what it does exactly.
All of my local pumps have a single nozzle for gas so can't get away from the 4 gallon rule.
« Last Edit: November 28, 2012, 10:04:15 PM by MotoRandy123 »
mono
« Reply #25 on: November 28, 2012, 08:49:14 PM »
Quote
I think we all should fill 5 gallon gas cans to 4 then add water then siphon the pure gas into our
scooters and dump the water/ethanol on the ground at the station!
Don't spill the ethanol !! After separating it this way, it's diluted with water and some tasty gasoline residues, effectively making it a cheap wodka  ;D
Joking aside, I've been thinking about decontaminating gasoline this way... The problem is that the only useful effect of ethanol is that it improves octane rating.... Which means that the gasoline it's mixed with probably has a lower octane rating than the sticker on the pump says... So, when you remove the ethanol from the mix....
Perhaps it's possible to install a knock sensor from a car, to be warned as soon as the cleaned gasoline causes detonation, and keep a small bottle of octane booster under the seat, just in case...
« Last Edit: November 28, 2012, 08:51:06 PM by mono »
MotoRandy123
  • Lets Ride!
« Reply #26 on: November 28, 2012, 10:11:24 PM »
I found this online;
"Ethanol has a higher octane rating than gasoline, about 116.
 When you 10% ethanol into 87 octane gas you get about 90 octane as a result."
So our 87 becomes 84 when we take the ethanol out? Hmm better start with 91!
ophelia
« Reply #27 on: December 04, 2012, 05:48:23 AM »
Ethanol is used as an octane booster and as a oxygenate to help the mixture burn more completely for reduced emissions. Previously, greater amounts of MTBE was used as octane booster and oxygenate, but MTBE leaks from storage tanks can be toxic to the environment (and way before that, we used tetra-ethyl lead in our fuel for octane boost). The base fuel stocks now come in lower octane ratings than before, relying on ethanol to raise the octane rating to the values we need in regular grade and up. Ethanol can be a clever and useful substitute. I personally don't like ethanol coming from corn here in North America, but that's a different discussion altogether. Small engines and automobiles engines for a few decades now have been designed to run just fine on the small amounts of ethanol in today's gas. The hoses are resistant to the little amount of ethanol. Small amounts of ethanol won't corrode aluminum like in our throttle bodies and carburetors and engines. Large amounts of ethanol will. Thus, don't put E85 in our bikes and don't go higher than E10.
Sometimes, higher octane fuels will contain less ethanol or even no ethanol. The octane rating can be raised with other chemicals, like MTBE and aromatics. As I understand it, sometimes these aromatics don't burn quite as cleanly, so extra detergent is added in premium fuels compared to regular grade fuel. That's why I don't see buying premium for extra detergent to be worthwhile. If you need extra cleaning, get a bottle of Techron concentrate or Gumout Regane.
If you ride the bike regularly, the gasoline shouldn't degrade and lose octane rating enough to matter. I recommend stabilizing fuel in scooters and motorcycles if they're going into storage for a few months or more. Ethanol-free or ethanol-reduced fuel might be worthwhile too.
As for fuel stabilizers, a product like Startron or Stabil basically envelops the ethanol molecules and prevents them from reacting with water. It's very useful in marine engines because they're exposed to lots of water! A fuel stabilizer also acts as a sacrificial substance to stop harmful reactive compounds like oxygen from oxidizing and degrading the gasoline into varnish. Keep in mind that fuel stabilizer should be added to fresh gas; it won't make stale gas any fresher.
I personally run regular grade fuel with ethanol in my bikes and cars unless they specify premium fuel for performance.
« Last Edit: December 04, 2012, 05:50:21 AM by thesurgeonistherobot »
2011 Kymco Downtown 300i
Aceforever
« Reply #28 on: August 08, 2013, 09:42:30 AM »
Oopps...I forgot to reply back to say thank you all for this useful information. I am very appreciated for this.
I went with my instinct and stuck with premium since it only cost $6-8AUD to fill up ;)
Thanks again
partyhut
  • imstilriden
Re: Unleaded or Premium Petrol[SOLVED]
« Reply #29 on: August 08, 2013, 01:22:23 PM »
old geezer   I`m impressed.  that is the clearest and most informative response post that I have seen on this forum.
scootenalong in
Soddy Daisy, Tennessee
