Author Topic: Spark Plug Question  (Read 5362 times)
big blue
Spark Plug Question
« on: November 01, 2012, 04:00:01 PM »
Hi scooter folks, I wanted to know if anyone has an opinion on switching the stock spark plug for a platinum or iridium one. I use NGK platinums in the car because they last longer and work well with cdi ignition. Since plugs in scooters are easy to change and need changing more often, is there a performance difference?
Lucasan
Re: Spark Plug Question
« Reply #1 on: November 02, 2012, 01:06:33 AM »
Very good question. I've been wondering the same thing myself.
« Reply #2 on: November 02, 2012, 02:05:01 AM »
Of course you can... and you're are right bigblue on the long life thing... premium metals last longer than your traditional copper...
TroutBum
  • 2012 Like 200i (sold)
« Reply #3 on: November 02, 2012, 04:27:33 AM »
You could, but why? Spark plugs are cheap. Personally I would use the original and replace it when necessary. YMMV
« Reply #4 on: November 02, 2012, 05:18:18 AM »
Yup, why... I did not... I still use the copper electrode and change it when necessary..  ;)
Zimmerman
  • Northeastern Pennsyvania USA
« Reply #5 on: November 02, 2012, 09:40:00 AM »
Doesn't iridium result in better Preformance ?
Kymco Yager GT200i
Kymco People 150
Yamaha Riva 125
big blue
« Reply #6 on: November 02, 2012, 03:51:11 PM »
That is exactly what I am asking about. I know that the Iridium plugs last longer(good in applications where it is difficult to change) but do they give improved performance? Would one expect better mileage, speed, smoothness? ???
juice
« Reply #7 on: November 02, 2012, 04:50:21 PM »
iridium plugs do perform better , but on a well maintained properly functioning motor you may not be able to detect any noticable difference . It will start easier and the plug will last much longer . I have been using them in all my vehicles and think the small extra expense is more than worth it  , especially in a single cylinder application . Good luck .
MotoRandy123
  • Lets Ride!
« Reply #8 on: November 02, 2012, 11:40:22 PM »
That's the first thing I did to my scoot. The fine wire arc's over sooner
so advances the timing 1/2 degree or so. It's only a little but adds a tiny
bit of power. The bike runs smoother and gets slightly better mileage too.
They don't wear out hardly at all so just pop it in and forget about it for 10
years or so...
« Reply #9 on: November 03, 2012, 01:08:52 AM »
Everybody's right... it's more on the long life thing...  ;) But of course, manufacturers have to focus on "POWER" or "PERFORMANCE" to get the consumers attention..
big blue
« Reply #10 on: November 03, 2012, 04:39:18 PM »
Many thanks for the opinions. I will probably switch to the iridium at next service and give it a try...Len
de-dee
« Reply #11 on: November 08, 2012, 06:01:38 AM »
   Do check your spark plug once a year so it will not freeze to your alum. block & if you put the scoot up for the winter a shot of oil in the cylander is good,.
       300i dt. givi top box,  givi side boxes,  admore lights,. hid head lights, home made rack for the givi boxes,. battery lead for charger, good for jump start too,.
                                                          the golden hawk scooter
scooterchu
« Reply #12 on: November 11, 2012, 02:28:20 AM »
I was under the impression that anti-seize is made exactly for that. Also I believe denso plugs now come with an antiseize coating on the threads.
« Reply #13 on: November 12, 2012, 01:39:52 AM »
Yup....
JOB
« Reply #14 on: February 20, 2013, 12:33:35 AM »
I Just bought an Autolite plug  (at Carquest) that is a direct replacement for the CR7HIX NGK Iridium plug and it cost me a whole $2.21 with tax. That's less than 10% of what the NGK goes for. Just thought I would share the news. JOB
