Author Topic: Jets  (Read 3855 times)
09agility50
Jets
« on: November 10, 2012, 02:10:37 AM »
I was curious of the main jet size(thread size). Also where is a good place to purchase them?
Bray0671
Re: Jets
« Reply #1 on: November 10, 2012, 02:14:09 AM »
I got mine from my dealership along with the smooth boss is was 10$ for both. But my A hole dealership made a note on the receipt that is was derestricting the scoot my self
09agility50
Re: Jets
« Reply #2 on: November 10, 2012, 02:29:45 AM »
My scooter came with a bigger jet and smooth boss so i put them in after break in. My last project was the NCY cvt kit. I just recently purchased the 72cc BBK and was wanting to play around with a bigger jet when it gets here.
Bray0671
Re: Jets
« Reply #3 on: November 10, 2012, 02:40:03 AM »
Nice did you have big improvements with the cvt kit
09agility50
Re: Jets
« Reply #4 on: November 10, 2012, 06:57:51 PM »
Yes i did like the improvements of the cvt kit, but i didnt use all the parts it came with like the springs in the secondary and the roller weights. I did a lot of testing with all the parts. Hopefully i can use those stiffer springs and different roller weights when the 72cc kit comes.
Any way the CVT kit does show improvements.
09agility50
Re: Jets
« Reply #5 on: November 10, 2012, 07:06:41 PM »
So back to my first question. The only thing i can find is M4x0.70 Threads. Does this sound right to anyone?
mono
Re: Jets
« Reply #6 on: November 10, 2012, 07:29:09 PM »
Nope : 4x0.70 is the standard metric coarse thread, which is exactly the type used in most cheap chinese Keihin-immitation carbs for the 139QMB engine... The standard Kymco carb has a thread that's closer to M5 (but isn't)...
You'll need a jet that's specifically made for a Kymco carb.
Only if you can't find one of those, you could try the Dell'orto small type jets, these will "fit with a bit of spit"  :P
Be careful though, it's possible to ruin a carb with the tight fit of these jets...
« Last Edit: November 10, 2012, 07:31:18 PM by mono »
09agility50
Re: Jets
« Reply #7 on: November 10, 2012, 07:41:54 PM »
any idea were to purchase them online? i have only found up to 85 size. Im looking for upper 80's maybe even low to mid 90's.
mono
Re: Jets
« Reply #8 on: November 10, 2012, 07:48:07 PM »
What's your setup ?
Did you install a big bore kit or a free flow air filter ?
09agility50
Re: Jets
« Reply #9 on: November 10, 2012, 07:50:35 PM »
I have the BBK and filter on the way. I was wanting to get the jets also that way when i am home over thanksgiving break i can mess with it when i install the BBK. There isnt really any local dealers or parts stores to get the jets is why i was asking about online.
mono
Re: Jets
« Reply #10 on: November 10, 2012, 08:48:42 PM »
What kind of BBK did you order ?
09agility50
Re: Jets
« Reply #11 on: November 10, 2012, 08:57:52 PM »
72cc
streido
Re: Jets
« Reply #12 on: November 10, 2012, 10:52:51 PM »
You want keihin M5/5mm threaded jets for the stock carbs  :)
Chaos is my co-pilot.
skippy
Re: Jets
« Reply #13 on: November 11, 2012, 08:58:52 AM »
i think the last american person thet asked got some from stadiamyamaha.
mono
Re: Jets
« Reply #14 on: November 11, 2012, 11:36:33 AM »
For a 72cc I would start with a size 88 jet, you can always go down to 66 if 88 is running rich...
Edit : unless you really want to use the free flow airfilter instead of the stock airbox, that is : with a free flow filter you'll need a way bigger jet, but you're pretty much on your own then, since they're all different... My advice : keep the stock airbox, on a 72cc with stock carb, those open filters are not worth the trouble they cause...
« Last Edit: November 11, 2012, 02:49:50 PM by mono »
