Author Topic: rear brake problem  (Read 1339 times)
Hans
rear brake problem
« on: November 11, 2012, 08:18:31 PM »
Hello, Ihave a major problem withmy xciting 500 2005 .
i have changed the brakepads with the original ones and used the book from  kymco , after i had changed the pads the brake pads are pushing the disk and i am worried now that the brake disk is overheating .
i can turn the wheel with one hand but there is resitance .
please i need advice i use the machine for driving to work every day about 175 kilometers.
thank you verry much
Hans (holland)
ts1
Re: rear brake problem
« Reply #1 on: November 11, 2012, 09:35:31 PM »
Hello Hans,
is it really the brake pads dragging the rear wheel? Usually with squeaking sound while turning the wheel? And you can't insert a thin thickness gauge between disk and brake pads (after a short riding)?
The final gear makes the wheel quite sluggish too!
But if it is the brakes, you might have made an assembly error. Perhaps reconsider your steps.
If you can speak German, the German Kymco Forum http://www.zzip.de/forum/ might be interesting for you. Its admin "Meister Zip" is a renowned authorized Kymco dealer and there are many (German and) international users, including some from the Netherlands.
sissy mary
« Reply #2 on: November 12, 2012, 02:48:30 PM »
A little resistance and noise of the pads sliding against the rotor is normal, more so with new pads. Alot of resistance is not normal. I would take it on a short ride, stop and then touch the rotor to see if it is really hot to touch or not. Don't burn your self. :-*
